GEN 2 Ecoboost 3.5 HO Details
TMW!
I know that the HO version has a shorter stroke which reduces the CR to 10:1. However what are the other intimate and important differences that make this engine different than one in a King Ranch or Lariat?
Do the heads flow better?
Are the cam shafts different?
Is the intake and Throttle body different?
Turbos- are they bigger or have different impellers?
Also, are the blocks aluminum or compact graphite?
T
TMW!
It has a shorter rod length. It's in the Ford Website
CatchMeOffroad
USA
I also am very interested in this same question.
xrocket21
Maine
If the crank is the same it does.
Stroke is the distance the piston travels, and this is determined by the crank. The stroke may be the same, but the displacement/compression ratio may be altered by changing the length of the rod.
T
TMW!
Let's talk about the heads and cam etc. The rods are indeed shorter, if the stroke is the same great.
Do you guys know anymore?
