GEN 1 Dead Battery & "Park" Indicator
weaponized
US
Had a battery fail and leak recently and replaced it with an Optima. All was fine for about 2 weeks then this morning the new battery was dead.
Put a charger on it and noticed that the backlighting on my gauges doesn't turn off after shutting the truck off after a few minutes, and when running through the shifter positions all the gear position lights work except for the "park" position.
Also the remote start has been acting up sometimes...in hindsight, likely because it thinks it's not in park.
Code reader indicates no codes.
After searching I found one post that mentioned something about a shifter solenoid but it didn't go in depth and I could find no other mention of it. I think it has something to do with the park position sensor or whatever but want to be sure before I take it to the dealer so they're not chasing their tail trying to figure this out.
Anyone experience this?
Sent from my SM-G965U using Tapatalk
W
weaponized
US
Welp...the shifter is bad and needs replacement. Internal switch that can't be replaced separately.
Freakin F150. I mean ( cough cough) Raptor
Sent from my E6910 using Tapatalk
WNCHSTR96
Athens, Alabama
So apparently this just happened to me. Saturday I accidentally washed my key and put it in a bag of rice. Sunday morning while out of state, I went to leave and noticed my courteous lights were on. I didn’t press the unlock button so I checked the rice back and realized I left the battery in the key fob. Took it out, use the spare started the truck and drove home and parked it in the garage. Monday, time to go to work, truck is dead. Can’t get it out of park to push it away from the wall to pop the hood so I take the wife’s vehicle. Needless to say, getting it out of park was more complicated that it should be. Pulled the center console like the manual suggested and pushed in the plastic piece to put it in neutral. Put the battery on charge and go to the store. Noticed the dash lights were illuminated when I got back. Quick google search turned up the park indicator switch, and the need to replace the shifter assembly ($600+ Ford replacement). It also turned up the switch on eBay for less than $20 which should be here Saturday. Did the dash check with the red indicator going away on the dash when put I park. With the battery charged I started it up, pulled it out of the garage to go through the dead battery steps in the manual. By pulling the #11 fuse on the passenger side the dash gets no power to drain the battery. However I can’t seem to get the stupid key out of the ignition now. I put the fuse back but still can’t get it out. Maybe I knocked something out of alignment at the shifter or something, I just don’t know. Will be working on it this weekend so when and if I get it fixed I’ll post my findings and solution. If anybody has had this issue hit me up as I’m pretty confident about the switch causing the dash lights to stay on draining the battery, but not sure if it’s related to my key not coming out. It’s a 2012 with 181k miles. Thanks in advance!
WNCHSTR96
Athens, Alabama
You got a source for that switch?
Sorry for the delay, didn’t see the alert.
https://www.ebay.com/p/2305588973 Hopefully this link paste job works. If not, do what I did and go to eBay and search for 2011-2014 Ford F150 F-150 Instrument Cluster Repair Dash Light Staying on Fix
