Cam Phasers Missing Gasket ML3Z-6584-G
sccs
Apparently these are on backorder. Does anyone know where I could find the valve cover gasket ML3Z-6584-G
Thanks in Advance
Old-Raptor-guy
USA
The last letter is the "revision level" so that part has been revised a few times. Chances are either A is old stock that a dealer did not return for credit or if you order an A you will end up with a G as the parts catalog may be delayed on updating the part number. Theoretically there should be a B,C,D,E,F but i have seen them skip when there is a rather large revision done.
