Alpha 1 vertical tire rack
Status
Not open for further replies.
SVTLOPEZ
selling my alpha 1 vertical tire rack in the Houston area. Has space for (2) max 37" tires, 5 gallon VP gas can, yeti cooler and space for jack and mount. selling for $700 PM me for more info.
D
Deleted member 12951
Guest
Does it extend out to the rear bed bolts by the tailgate? How does the Yeti cooler tie down? A picture further away perhaps?
Mluis11
I have the same rack...no it doesn't extend to the rear bolts. It only uses the front 4. As for the yeti, I'm guessing he is referring to where the 8 gallon tote is located on the link. I've been very happy with mine and it can be installed or removed in literally 1 minute.
http://outlawoffroad.com/i-20991786-alpha-1-vertical-tire-bed-rack-for-ford-raptor.html
D
Guest
Alpha 1 Vertical Tire Bed Rack for Ford Raptor
I've seen some custom Alpha 1 racks that do extend to give you some more tie downs. I've been wanting to get this rack hence why I was asking. I knew about the top holding the 8 gallon action packer. What size Yeti cooler would fit in there?
Mluis11
A very small yeti if that's the spot he is talking about. Google 8 gallon tote deminsions...its a snug fit side to side and has 1-2" of room from front to back.
D
Guest
I already have an 8 gallon Action Packer tote by Rubbermaid. I just didn't know a yeti would fit in there. I would most likely use it for the action packer and was interested if perhaps a larger yeti and another box could be tied down behind it without having to install something different to accommodate the rack.
What jack and skid are you using?
SVTLOPEZ
SVTLOPEZ
It holds a 20 yeti and any equivalent cooler perfectly. I use a pro eagle 2-1:2 ton but I don't have the mount on the tire rack. I need a base for the jack and mount to be able to put the jack in it's designated section
SVTLOPEZ
SVTLOPEZ
Here's more pics
Status
