2021 going in for 15,000 mile service
Raptor916
I feel an oil change and tire rotation is all that is needed. Should I request just that or have them do whatever the hell they add to it?
Keith88
Boise, ID
oil change n tire rotation and youre good to go. Just check the filters and truck over.
figure1a
San Diego
They have a list. It's mostly do a quick once over on the truck for leaks. Hook it up to the computer to check for codes. Then squeeze lube into all the zirc fittings. Oil change. I usually rotate at 10K because the most I ever get out of KO2s is about 20K.
Littlefx4
Follow your scheduled maintenance plan (find it in Ford Pass app) & you can’t go wrong.
SurfRaptor
Newport Beach CA
Where are the zerk fittings? I haven’t seen one yet.
RamseyF
michigan
change those filters quicker than they say. 20k is about right for the in cabin filter but I just do it every twelve mths. 15-20 k. and 30k for the engine air filter is rediculous, that should be 15-20k as well IMO. I do that every 12 mths as well. do yourself a favor and do it yourself. cabin filter and engine air filter are a 5 minute job. tops. combined and thats if you slam a beer in between installing the two of them.
