Take them out of the truck, turn them upside down to dump the water out then, blow with compressed air and let dry overnight out of the truck. Run a bead of clear silicon around the seals. Reassemble and throw a few desiccant packs in the hole where the bottom bulb goes. Been down this road and no issues since.
Think I will do that when/if I get these replaced. Thanks for the suggestion. Do you silicone over the breath holes too?
Rick its pretty obvious they were dusty inside then condensation built up, splashed around and caused the muddy water... clearly a seal issue. If you know what i mean.
Will do, thanks!
