2013+ Dash Bezel Swap on 2011
SVT_Mayo
Lincoln, RI
2013+ Dash Bezel Swap on 2010-12
This might be a stupid question, but has anyone tried to just switch the bezels from the 2013/14 to 2010-12? I've only found threads where people want to swap MFT in. This is just an idea that hit me today. I don't care about the MFT system or anything, havn't had a problem with the one I have and like it. The 10-12 Screens are the same size and look to be in the same spot anyway I believe, I just want to know if it'd be possible to switch the bezels. I like the heat controls better on the 13 bezel. Really my only reason.
aka grumpy car stereo guy
not worth the effort to try this. it will most likely cost way more than you would want to spend. the clock and tray you have above the radio will need to be modified along with other issues. but the biggest one will be that the heater control connections are different and it will probably be a programming issue that will keep it from being compatible.
SVT_Mayo
SVT_Mayo
Lincoln, RI
Good point on the heater control programming. Was unsure about the plug and play of the physical buttons to begin with.
Well todays idea is probably dead.
