Audio solutions for your Raptor
aka grumpy car stereo guy
I saw in the couple pics posted that the sub fires into to bottom of the seat. How does that affect the performance of the sub(muffled)? In my older F-150 I had a under the seat sub box and it fired down with about an inch of clearance.
It really doesn't matter firing direction normally, but these are deigned to handle off roading A down firing woofer in our application might rip the woofer screws out on a hard landing. That's why I am doing an up firing setup
Duke240
Form and function... I see. Totally make sense.
Yukon Joe
Trafford, PA
Noah,
Thanks for the phone call last night. I had a chance to reivew the different level packages you offer. I think I have a better understanding of the whole set up.
I'm thinking the Level 1A package would be more than enough for my truck.
You better send some detailed wireing instructions...
:wizserious:
EDIT:
I really like the SVT style box
http://www.fordraptorforum.com/f202/audio-solutions-your-raptor-20172/#post398048
Wilson
South Dakota
Noah get it to Joe before sdbr and Joe get it in before sdbr so I can hear it. Noah don't get to existed this will be one of my last mod's. probably more than 2 years out or longer or even longer.
finally found it. ok joe, if you are serious, i will start the box build tomorrow for you. i will try to integrate the svt in the box...... crap.......... i have most of the product in stock, so that wont be an issue. the box is the only holdup i just realized that you have a crewcab. i have an idea of mounting it so im going to run with it.
fshol
The Netherlands
Here is a setup that we at The Car Stereo Company have come up with, as an entry level audio upgrade package. This is the level 1 package which will be a huge increase in sound quality and volume, that we are missing in our trucks. Stay tuned for level 2, 3 and 4 coming soon
after converting to a pdf format the pictures became a little blurry. we will fix it soon. sorry everyone
Are the speakers a direct replacement for the factory ones? I would like to start with replacing the speakers and do the rest later on. I simply can't spend whole days on doing work on my truck, so i have to spread it.
wanderfalk
how long would it take for you to install a level one?
yes they are pretty much a drop in fit. tweeter mounting will take a little work, but nothing crazy. i can replace all the speakers in about an hour and a half.
it depends on where i am installing it. if i am out in a field with limited resources, it takes about 12-15 hours. if i am in my shop, it takes about 8 hours. the install time doesnt vary much between the different levels of packages. the factory amp integration and running wires is a time consumming process, and is something that has to be done with these setups.
fshol
The Netherlands
Tweeter mounting? Thought the TR570-CXI was a coaxial speaker. Or do you mean wiring the tweeters from the pillar location to the front doors?
You also mentioned the C3570. Do these tweeters install in the pillar location?
93,363
56,644
LDMiles
