Dealer Bulk (“works”) used oil analysis
thatJeepguy
thatJeepguy
GA
thatJeepguy
thatJeepguy
GA
Your silicon levels are nearly twice average. That's usually dust getting past the air filter.
You running the stock air filter/intake?
Hmm i didn't notice that. Perhaps some residual from phasers work? Rtv on the timing cover? If i dusted the motor i would assume more wear which is low.
thatJeepguy
thatJeepguy
GA
So I ran amsoil SS 5w30 after I drained that dealer bulk “motorcraft” oil out. Here are the lab results. After 3k miles the frikken oil was so dark i wanted to get it out of there. So I had it changed. Here are the results.
EricM
OHIO
The silicon level is way lower in your latest analysis. Do you run a K&N type filter or CAI?
thatJeepguy
thatJeepguy
GA
That’s a negative. I still think that the high silicone was from when they used RTV to reseal the timing cover during the cam phaser repair. I run regular asś pleated filters from Motorcraft purchased at Walmart.
