GEN 2 Big Brake Kits
dinoone
I love wilwood most what I use. They have been saying that for 6 months prior on their kit why I went with Brembo
Not all I am looking for, a BBK changes the big as mentioned before so that will ultimately improve braking performance while looking better.
---------- Post added at 10:19 AM ---------- Previous post was at 10:18 AM ----------
I have confirmed with Wilwood that they have not released their kit for the 17 Raptor and the current kit for F-150's will not fit without modifications. They said 90 days on their new kit.
Jayrod
Jayrod
FL
Ok also just confirmed that Baer does have a kit for the Raptor it is as follows.
Front 2 piece rotor BBK for 20" wheel- Part # 4261409
Rear 2 piece rotor BBK 20" Wheel- Part# 4262688
---------- Post added at 11:17 AM ---------- Previous post was at 11:08 AM ----------
I figured it was a pipe dream
Jayrod
Jayrod
FL
SilverBolt
Hired Gun
Portland, OR & Eureka, MT
BajaFred
Nobody gets banned around here. Since the stock brakes can lock up the stock tires with ease a bbk won't be much of an improvement. Pads, rotors, and brake lines can improve the bite, fade, and feel.
Maybe this got cleared up later in the thread
You need to clarify, not much improvement for the first panic stop
Thereafter ie repeated heavy use is why you get a BBK
For the first panic stop, OEM is more than sufficient
---------- Post added at 08:44 PM ---------- Previous post was at 08:40 PM ----------
Yes, if that's the Extreme+ setup for the 2015+ trucks, it will work on the Raptor
It's hard to beat Brembo, but I like Baer too since they're the only ones I know of whose rear caliper is the same size as the front
Doesn't do squat for better braking but the $$$ is the same, I like the look of same sized 6p setup on all 4s
Jayrod
Jayrod
FL
Decided to give Freedom Motorsports a shot and did the BBK from R1. Looks nice and 8 piston front, 6 piston rear, 2 piece rotors, etc. good price as well.
Bullishone
What size did you get?
Jayrod
Jayrod
FL
Rotors are 2 piece Drilled and slotted 405 MM Front, 380 Rear, 8 Piston Cal front and 6 Piston rear. Comes with SS lines, Pads etc. They will do any color combination you want in either gloss or anodized. Freedom worked with R1 for a direct bolt kit for the 17 Raptor. Build time is 4 weeks, which, is fine waiting on the wheels anyway.
https://www.r1concepts.com/bbk_interactive/
93,180
56,460
khunter
