See our website for our ZL1 specific packages. We can also build a package to fit your needs.
Specs:
Delivered by Rodger’s Chevrolet 4-27-12 (yes, we’ve only had it 2 weeks!)
2012 ZL1 Auto trans - Full weight with exception of wheels/tires
100% stock suspension
Stock trans w/ Livernois specific trans calibration
Stock catback
4,295 lbs. with driver
240 Miles
Mods:
Livernois Motorsports In-House CNC LSA Cylinder Heads
Livernois Motorsports Stage 2C High Lift Camshaft
Livernois Motorsports LSA Head Studs (Available soon)
Livernois Motorsports Exclusive Heat Exchanger (Available soon)
Livernois Motorsports Solid Supercharger Coupler
Livernois Motorsports Supercharger Pulley
Livernois Motorsports Exclusive Steel Idler Relocation Bracket w/ Metco Pulleys (Available soon)
Livernois Motorsports Spec’d Injectors
Livernois Motorsports Dual Fuel Pump Upgrade
Precision Industries Converter Built to Livernois Specs
Metco Oversize Crank Pulley Ring
Innovators West Oversize Balancer
Rotofab/Livernois Cold Air Intake (Available soon)
Stainless Works Longtube Headers & Connection Pipe
Hardened Pushrods
NGK TR6 Spark Plugs
160 Degree T-Stat
GM 90mm Throttle Body
Bogart 17” Wheels w/ Slicks & Skinnies
Livernois Motorsports Dyno Tune
Dyno Results Stock:
476 RWHP / 476 RWTQ
The best pass 100% stock with 110 miles on the odometer was 12.41 @ 115.9 mph. It was traction limited and the track was extremely busy, so I didn’t get a good feel for the car and how to launch it.
Dyno Results Modified:
707 RWHP / 680 RWTQ (Roughly 850 crank HP)
Note: Our tuner Dan Millen was at the track with me all day logging each pass and getting more and more aggressive after each pass, so I’m sure the power was quite a bit higher than what we saw on the dyno.
Just a little info on Dan, he is a multi-time 10.5 tire world champion who always sets the bar for the class. His car runs 3.7X @ 204 mph in the 1/8 mile!
I wouldn’t hesitate to daily drive the ZL1 with these mods (minus the wheels/tires).
I do plan on driving the car to Rodger’s Chevrolet for their show/open house tomorrow, then back to Milan on the stock wheels and Mickey Thompson ET Street Radials to see what it will run on 20’s.
The first pass off the trailer today, the car went 10.14 @ 138 MPH. Many of my launches were from just above idle and it was like a bracket car with several 10.0X-10.1X passes @ 138-141 MPH, and FINALLY on the last pass 9.87 @ 142 MPH!! Dan got pretty aggressive with the tune and told me to leave as hard as I could off the converter. We WERE going 9’s on this pass! I did the burnout, staged, then focused… not worrying about my reaction time (it was horrible as you can see), put it on the converter until it felt like it was going to roll forward and let it rip. I knew at the end of the track it was a good pass when I saw 145 mph on the heads up display.
We are also currently working with PSI Superchargers to improve the factory blower. Dan runs a PSI screw blower on his 3-Second 200+ MPH 1/8 mile race car.
Huge Thanks to:
GM for building an awesome car, Rodger’s Chevrolet, Milan Dragway for the great track, Innovators West, Metco, Mickey Thompson Tires, Precision Industries, Rotofab, Stainless Works… and the technicians at Livernois Motorsports!!!!!!
Vehicle Transport Services:
We realize that many of you are quite a distance from our Dearborn Heights, MI location and have interest in our services, but are not able to make the drive due to work and busy schedules.
We have a single vehicle enclosed trailer or a two vehicle enclosed trailer if there are two vehicles in close proximity to each other. With this service, you can trust that your car will make it to our location and back to you safely, and with much more power than it arrived with!
Cost of this service is very reasonable, but varies based on a distance and the availability of our trailer.
All cars are stored safely in doors before and after work is performed.
Please call 313-561-5500 or email [email protected] for information and pricing.
Thank you
Regards,
Rick LeBlanc
Specs:
Stock catback
240 Miles
Mods:
Hardened Pushrods
NGK TR6 Spark Plugs
160 Degree T-Stat
Dyno Results Stock:
476 RWHP / 476 RWTQ
Huge Thanks to:
Thank you
Regards,
Rick LeBlanc
