Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford SVT Raptor General Discussions [GEN 1]
This is a discussion on What did u do to your raptor today? within the Ford SVT Raptor General Discussions [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
Intake pressure, exhaust pressure, shock pressure that's already 4, and volts for all the lights getting hooked up....
Antlers, upscrazy8
Like Tree31161Likes
Old 02-21-2017, 07:15 AM   #15921 (permalink)
The258's Avatar
2010 SVT Raptor 5.4L Blue Flame Metallic #1798
The258 is offline   Reply With Quote
Old 02-21-2017, 11:10 AM   #15922 (permalink)
J DAMAGE's Avatar
Originally Posted by RLTW View Post
Seriously, what 7 things do you need to keep your eye on that badly.
Not badly , because I want to.
Volts
Trans temp
Oil pressure
Oil temp
Water temp
Wide band air/fuel
Vacuum.
I know oil & water will be close but , going in anyway, one may be replaced with my air gauge for my onboard air.
RLTW and Mluis11 like this.
J DAMAGE is offline   Reply With Quote
Old 02-21-2017, 01:02 PM   #15923 (permalink)
RDFTS's Avatar
aka Rick
Default What did u do to your raptor today?
Well found this today when changing out the bent wheel. Geez the list keeps growing
Nice chunk missing
2014 RR SE SCREW | #792 of #3396 in RR | #4568 of #22409 Total | My Mods: Click Here
2008 Shelby Mustang GT500 Torch Red Convertible | #58 of #463 in Torch Red | #249 of #2070 Total
Raptor Runs: TRR & Raptoberfest 14'/15'/16'/17'/18' | Time Attack 14' | Snoball 15'/18' | AR Run 15' | TRR Baja 16'/18' | Private Baja Jan 17'
RDFTS is offline   Reply With Quote
Old 02-21-2017, 04:31 PM   #15924 (permalink)
Trick_Raptor's Avatar
The Cracker Raptor
Did a spindle upgrade. SVT Raptor Reinforced Front Spindle
I had the spindles powder coated. I asked for pink but I guess that color wasn't available. Thanks to @Stagecoach (Paul) and @Lynxs961 (Matt) for the upgrade! Thanks @oxfordraptor for the beer!
Trick_Raptor is offline   Reply With Quote
Old 02-21-2017, 05:08 PM   #15925 (permalink)
oxfordraptor's Avatar
Anytime buddy.
Lynxs961 likes this.
oxfordraptor is offline   Reply With Quote
Old 02-21-2017, 05:18 PM   #15926 (permalink)
RDFTS's Avatar
aka Rick
I had no idea they were offering these now. Definitely cheaper than the SDHQ alternative that I have, look identical though. See you opted for the double sheer option for down the road. So when are you upgrading the tie rods?
I went with the SDHQ ones myself to go with the knuckles.
Trick_Raptor likes this.
Old 02-22-2017, 12:12 AM   #15927 (permalink)
The Cracker Raptor
My tie-rods are worn and need to be replaced right now (along with my converter seal). I'm just going to have them replaced under warranty for the time being.
Next round will most likely be from my guy at WOG.... the Blitzkrieg Motorsports Tie Rod Kit though I do like the RPG one as well..
Old 02-22-2017, 01:28 AM   #15928 (permalink)
RLTW's Avatar
Volts
Trans temp
Oil pressure
Oil temp
Water temp
Wide band air/fuel
Vacuum.
Gotcha, looks like it'd appear too cluttered for my tastes, but I hope it comes out clean.
ICON 3.0 - ICON UCA - ICON Leaf Springs - SVC Bypass Rack - Custom King 4.0s - ICON BUMPSTOP/FRAME SUPPORT - RPG TIE RODS - ICON LCA SKIDS - UMP INTAKE - MBRP TURDOWN W/RES - 5STAR TUNE - METHOD 17" 105 BEADLOCKS - 37" BFG BAJA T/A KR - RPG RACELINE FRONT/REAR BUMPER - R1 BRAKE PACKAGE WITH AMSOIL FLUID AND SDHQ SS LINES - 5 x 6.7 VIS X LIGHT CANNONS - BD 60" ONNX ARC RE - BD S2 RE - LINEX BED - CRAVEN STUBBY
RLTW is offline   Reply With Quote
Old 02-22-2017, 09:31 AM   #15929 (permalink)
J DAMAGE's Avatar
It's sitting at 5" , not to bad, but you are correct, it can take on a whole different look with gauges installed, if that is the case I will end up putting 4 there, and using the A pillar for the rest.
Old 02-22-2017, 10:55 AM   #15930 (permalink)
t_j's Avatar
t_j
These ones seem to be the SDHQ ones with installation, way cheeper than the SDHQ installed version. Seems a little cheep TBH as the install is a hugely labour intensive process if done correctly.
t_j is offline   Reply With Quote
Got my Raptor today. AURAPTOR 2013 Ford SVT Raptor Forum (Reply Only) 21 10-28-2012 11:34 AM
Just got my raptor today!!! BENO New Member Check-In 12 12-24-2011 07:47 AM
Raptor Born Today! BWMEEKS Prospective Raptor Owners 11 04-18-2011 10:34 PM
Got My Raptor today! raptorort Ford SVT Raptor General Discussions [GEN 1] 7 04-18-2011 02:25 AM
