So does your Raptor fit height wise in your garage?
hagak
Also adjust your garage door opener travel to make it raise as high as possible. I got about 2" more of clearance just doing that.
Thanks for that I just went out and adjusted my opener. I now have just over 83" up from just under 80". So with that much clearance I should have no issue.
BAJA1K
You will be fine with 83". I have mid perch with 35" generals and truck is about at 80". Glad I could help.
hagak
Well it fit. Height is just fine. Length is well close. Have a whole 20" to spare total between front and rear. Will be hanging a tennis ball from the ceiling to mark my position, was able to use the front camera to aid, wish you did not have to go into offroad mode and 4x4 or locked diff to enable it. I assume that requirement is some lawyer cope out just like the damn butt switch on my tractor.
