Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 2 (2017+) Ford F-150 Raptor Forums > Ford Raptor Suspension Discussion and Modifications Forum [GEN 2]
Big Brake Kits
This is a discussion on Big Brake Kits within the Ford Raptor Suspension Discussion and Modifications Forum [GEN 2] forums, part of the GEN 2 (2017+) Ford F-150 Raptor Forums category!
I love wilwood most what I use. They have been saying that for 6 months prior on their kit why ...
Like Tree56Likes
Old 06-08-2017, 10:54 AM   #21 (permalink)
dinoone's Avatar
I love wilwood most what I use. They have been saying that for 6 months prior on their kit why I went with Brembo
Originally Posted by Jayrod View Post
Not all I am looking for, a BBK changes the big as mentioned before so that will ultimately improve braking performance while looking better.
---------- Post added at 10:19 AM ---------- Previous post was at 10:18 AM ----------
I have confirmed with Wilwood that they have not released their kit for the 17 Raptor and the current kit for F-150's will not fit without modifications. They said 90 days on their new kit.
RDFTS likes this.
dinoone is offline   Reply With Quote
Old 06-08-2017, 11:17 AM   #22 (permalink)
Jayrod's Avatar
Ok also just confirmed that Baer does have a kit for the Raptor it is as follows.
Front 2 piece rotor BBK for 20" wheel- Part # 4261409
Rear 2 piece rotor BBK 20" Wheel- Part# 4262688
---------- Post added at 11:17 AM ---------- Previous post was at 11:08 AM ----------
I figured it was a pipe dream
Jayrod is offline   Reply With Quote
Old 06-08-2017, 12:56 PM   #23 (permalink)
SilverBolt's Avatar
Hired Gun
I do know that 355mm rotors are the largest that will clear an 18" wheel. That also depends on the center/spoke configuration of the wheel.
2012 Toyota FJ Cruiser
2018 Raptor Screw 802A White
SilverBolt is offline   Reply With Quote
Old 06-08-2017, 02:17 PM   #24 (permalink)
dredge38's Avatar
https://alconkits.com/shop-alconkits...ake-kit-detail
A lot of trophy truck guys run this brad and I know they are on the Deberti raptor. Doesn't look like you need to run larger wheels either.
dlbb likes this.
dredge38 is online now   Reply With Quote
Old 06-08-2017, 02:48 PM   #25 (permalink)
Jayrod's Avatar
Interesting I did not know about this company, they do charge a premium those rears are on par price wise with Baer and Wilwood.
Old 06-08-2017, 03:31 PM   #26 (permalink)
SilverBolt's Avatar
Hired Gun
Alcon has been around in the racing world for decades. Good quality product but not cheap.
dredge38 likes this.
Old 06-08-2017, 08:44 PM   #27 (permalink)
Originally Posted by dude1782 View Post
Nobody gets banned around here. Since the stock brakes can lock up the stock tires with ease a bbk won't be much of an improvement. Pads, rotors, and brake lines can improve the bite, fade, and feel.
Maybe this got cleared up later in the thread
You need to clarify, not much improvement for the first panic stop
Thereafter ie repeated heavy use is why you get a BBK
For the first panic stop, OEM is more than sufficient
---------- Post added at 08:44 PM ---------- Previous post was at 08:40 PM ----------
Rear 2 piece rotor BBK 20" Wheel- Part# 4262688[COLOR="Red"]
Yes, if that's the Extreme+ setup for the 2015+ trucks, it will work on the Raptor
It's hard to beat Brembo, but I like Baer too since they're the only ones I know of whose rear caliper is the same size as the front
Doesn't do squat for better braking but the $$$ is the same, I like the look of same sized 6p setup on all 4s
BajaFred is offline   Reply With Quote
Old 06-08-2017, 11:39 PM   #28 (permalink)
Jayrod's Avatar
Decided to give Freedom Motorsports a shot and did the BBK from R1. Looks nice and 8 piston front, 6 piston rear, 2 piece rotors, etc. good price as well.
Old 06-09-2017, 07:23 AM   #29 (permalink)
Bullishone's Avatar
What size did you get?
Bullishone is offline   Reply With Quote
Old 06-09-2017, 09:26 AM   #30 (permalink)
Jayrod's Avatar
Rotors are 2 piece Drilled and slotted 405 MM Front, 380 Rear, 8 Piston Cal front and 6 Piston rear. Comes with SS lines, Pads etc. They will do any color combination you want in either gloss or anodized. Freedom worked with R1 for a direct bolt kit for the 17 Raptor. Build time is 4 weeks, which, is fine waiting on the wheels anyway.
https://www.r1concepts.com/bbk_interactive/
GEN 1 Brake Pad & Brake Rotor Upgrade RC51TOFUMAN Ford Raptor Engine Discussion and Performance Mods-6.2 Liter V8 [GEN 1] 11 12-15-2016 10:00 AM
Steering Wheel and brake pedal vibration after brake job BigGriff023 Ford SVT Raptor General Discussions [GEN 1] 7 07-19-2016 07:30 PM
Brake Kits at RockAuto.com RockAuto RockAuto 0 02-25-2015 03:42 PM
TSB 12-2-3 Red Brake Lamp On-Park Brake pirate air Ford Raptor Recalls | TSB's | SSM's 0 05-16-2012 03:47 PM
