Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
Ford Raptor Forums - Members Gallery
Ford Raptor Photos & Videos
Working on my Dirty Raptor Contest
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="JP7" data-source="post: 31851" data-attributes="member: 223"><p>That wasn't the worst dose of mud she's seen under the hood, but that bit I posted on the trail running thread was true - when your rad fans hit as much as an inch of muddy water - the whole engine compartment gets a bath.</p><p></p><p>The 40 minute drive home from the trails does a pretty good job of baking mud to objects - but I just blasted it out with a garden hose. Soak it first, then spray it. Don't recommend a pressure washer.</p><p></p><p>I bought a (can't remember the name, but it's purple) steam cleaner this winter, and found it pretty good for detailing the tight spots. It's also worked good at getting the salt deposits outta the carpet. (I don't care whether the floor mats are weathertech or stock - when you have a hole in it for the securement peg to poke through - all the melted snow/water/salt will go down that like a sink drain.)</p></blockquote><p></p>
[QUOTE="JP7, post: 31851, member: 223"] That wasn't the worst dose of mud she's seen under the hood, but that bit I posted on the trail running thread was true - when your rad fans hit as much as an inch of muddy water - the whole engine compartment gets a bath. The 40 minute drive home from the trails does a pretty good job of baking mud to objects - but I just blasted it out with a garden hose. Soak it first, then spray it. Don't recommend a pressure washer. I bought a (can't remember the name, but it's purple) steam cleaner this winter, and found it pretty good for detailing the tight spots. It's also worked good at getting the salt deposits outta the carpet. (I don't care whether the floor mats are weathertech or stock - when you have a hole in it for the securement peg to poke through - all the melted snow/water/salt will go down that like a sink drain.) [/QUOTE]
Insert quotes…
Verification
Post reply
Staff online
Griffin
Administrator
Members online
Spike Spiegel
stoppard stop
RenoRaptor1
Jeff Oldham
GAMike
cfmistry
ECW
Gumby
Bmwtech113
Robertcrav
915GT500
chizzleknizzle
Reptar854
Griffin
k3k0a808
reddot69
cazt51
HORN HIGH ACES
RaptorFun
03Cobraraptor
butts182
SSWIM
Simon001
ChasingGazelles
Lucas_Arg
brettmess24
mattbos80
aostrows
HeyItsARaptor
OEMPlus Raptor
AmaRaptor
pander952
pirates1456
ToadSmasher2K1
fordfreek
jimmyjamm
Nesc204
Sharpie69
tcm glx
Raptor_NV
CruiserClass
visionxp
shank_guru
DRC3
13terrain
Thunder Piggy
BIGW0RM
OBXRAPTOR17
MurderedOutSVT
MOT26
... and 43 more.
93,298
56,586
levileb91
Forums
Accept
Learn more…
