Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
Ford Raptor Forums - General Information
Ford Raptor Recalls | TSB's | SSM's
TSB 10-25-14 - Message center distance-to-empty range decreases and does not recover
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="pirate air" data-source="post: 202747" data-attributes="member: 27"><p>TSB 10-25-14</p><p></p><p>12/23/10</p><p></p><p>MESSAGE CENTER DISTANCE-TO-EMPTY RANGE</p><p>DECREASES AND DOES NOT RECOVER-VEHICLE</p><p>PARKED ON GRADE ONLY - BUILT ON OR BEFORE</p><p>10/4/2010</p><p></p><p>FORD:2009-2010 F-150</p><p> </p><p>ISSUE</p><p>Some 2009-2010 F-150 vehicles built on or before 10/4/2010 and equipped with a message center and distance-to-empty (DTE) feature only may exhibit the DTE range decreases when parked on grade with the front of the vehicle positioned down, but the range does not recover near the previous reading once the vehicle is operated on level ground. May be more noticeable when the fuel gauge indicates less than 1/4, and DTE is less than 240 km (150 miles). Extended idle with the vehicle parked in this position may contribute to the condition.</p><p></p><p>ACTION</p><p>Follow the Service Procedure steps to correct the condition.</p><p></p><p>SERVICE PROCEDURE</p><p></p><p>Reprogram the instrument cluster module (1CM) to the latest calibration using IDS release 70.03A and higher. This new calibration is not included in the VCM 2010.11 DVD. Calibration files may also be obtained at the website.</p><p></p><p>The customer will observe reasonable DTE range recovery after operating the vehicle for 15 minutes on level ground less the fuel used during this time. Some amount of filtering is required to prevent over reactive gauge and DTE operation, therefore instantaneous DTE recovery after this reprogram should not be expected.</p><p></p><p>WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage </p><p>IMPORTANT : Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.</p><p></p><p>OPERATION DESCRIPTION TIME</p><p></p><p>102514A 2009-2010 F-150: 0.3 Hr.</p><p> Reprogram The Instrument</p><p> Cluster (Do Not Use With</p><p> Any Other Labor</p><p> Operations)</p><p></p><p>DEALER CODING</p><p> CONDITION</p><p>BASIC PART NO. CODE</p><p>10849 04</p></blockquote><p></p>
[QUOTE="pirate air, post: 202747, member: 27"] TSB 10-25-14 12/23/10 MESSAGE CENTER DISTANCE-TO-EMPTY RANGE DECREASES AND DOES NOT RECOVER-VEHICLE PARKED ON GRADE ONLY - BUILT ON OR BEFORE 10/4/2010 FORD:2009-2010 F-150 ISSUE Some 2009-2010 F-150 vehicles built on or before 10/4/2010 and equipped with a message center and distance-to-empty (DTE) feature only may exhibit the DTE range decreases when parked on grade with the front of the vehicle positioned down, but the range does not recover near the previous reading once the vehicle is operated on level ground. May be more noticeable when the fuel gauge indicates less than 1/4, and DTE is less than 240 km (150 miles). Extended idle with the vehicle parked in this position may contribute to the condition. ACTION Follow the Service Procedure steps to correct the condition. SERVICE PROCEDURE Reprogram the instrument cluster module (1CM) to the latest calibration using IDS release 70.03A and higher. This new calibration is not included in the VCM 2010.11 DVD. Calibration files may also be obtained at the website. The customer will observe reasonable DTE range recovery after operating the vehicle for 15 minutes on level ground less the fuel used during this time. Some amount of filtering is required to prevent over reactive gauge and DTE operation, therefore instantaneous DTE recovery after this reprogram should not be expected. WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage IMPORTANT : Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part. OPERATION DESCRIPTION TIME 102514A 2009-2010 F-150: 0.3 Hr. Reprogram The Instrument Cluster (Do Not Use With Any Other Labor Operations) DEALER CODING CONDITION BASIC PART NO. CODE 10849 04 [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
Billy Mc
Johnny@Apollo-Optics
ljn21
10SpdsOfFury
IIAWAH808
jdm_sixtwo
SCAR911
jekyll537
blazn5667
HighSpeedLowDrag
Skmon
pirates1456
rgz
Bigperm
Swimmer
Raptor Rob
MORaptor1
wharrell
BBR
hdvvraptor
Bu3askoor
MDJAK
DutchDad
summands
ToadSmasher2K1
CessnaDriver
JD05
vill
Rustyseatbelt
DaveO
5280 Raptor
GCATX
Hambone
KevinBaz
RaptorAU
shigman
CleverGirl_
NickyF25
raptor730
aje0010
mikewills
Frogger22
encyphered
3wheelkhalil
eorodriguez30
KingKoopa17
Braaaaptor
oliver1539
RCorsa
... and 17 more.
93,187
56,468
ngodavid23
Forums
Accept
Learn more…
