Triple Fog Light Kits Featuring 100% American Made/Stainless Steel Brackets
4x4TruckLEDs.com
4x4TruckLEDs.com
Don't waste your money on the Radiance UNLESS the only reason you are getting them is for the back-light color. They have a pencil style spot pattern and it's NOT bright at all. Folks usually only get the Radiance for the back-light. If you want light that you can USE get the Baja Designs lights or the D-Series PROS from Rigid.
18RaptorOW
Los Angeles
I figured that was the case when no specs were mentioned for the Rigid radiance.
Looks like I’m going with the BD set up you mentioned back a page or so.
Thanks again for all your knowledge and info.
4x4TruckLEDs.com
4x4TruckLEDs.com
So our Triple Fog Light kits just got better. We're now including absolutely free (with the purchase of a full kit) our all-in-one wiring harnesses.
If you buy the kit with Baja Designs lights you get the harness that already has the Weather Pack connectors on it. Buy a Rigid kit and you're getting a harness with DT connectors on it.
Even better... our Rigid kits have an extra "control" wire for the Radiance lights. This lets you wire in the backlit feature of the Radiance lights... on all three pairs. So if you run 3 pairs of Rigid Radiance lights, all 6 of those lights will have the backlit feature on with the push of an upfitter (just leave the upfitter on at all times and the backlight will always be on when your truck is on).
If you buy our brackets alone, you have the option to add on our wiring harnesses for only $49.
FastEddie
Does the new BD harness tie all the lights into one upfitter switch or can it be used to individually switch the lights?
4x4TruckLEDs.com
4x4TruckLEDs.com
3 individual switches. If you wanted to use 1 upfitter switch (and you didn't max out the 15 amps on switches 1/2) you could either use a small y-splitter cable(s) or just wire all the hot leads together to the 1 upfitter wire (easier).
But out of the box our harness gives you control over 3 pairs of lights from 3 different upfitters
4x4TruckLEDs.com
4x4TruckLEDs.com
Don't get locked into what the manufacturer tells you you are running. With our SPP Triple Fog Light kits YOU pick the lights. YOU pick the lenses. YOU pick where they are aimed.
Want 3 Rigid Radiance? DONE. And you'll get full backlight control on all 3 pairs.
Want 3 Baja Squadrons? EASY!
Heck want 2 Baja Squadrons and 1 Rigid SAE? Not a problem!
Mix and match with custom kits.
Have existing lights that you want to re-use... then just pick-up our bracket kits and enjoy your lights again.
Email us for information on our trade-up program, where you can trade in your old components for new components.
Rigid Industries Radiance Kits ($569): http://www.4x4truckleds.com/2017-ford-raptor-triple-fog-light-kit-w-rigid-industries-radiance-pods/
Rigid Industries D-Series Kits (Starting at $669): http://www.4x4truckleds.com/2017-ford-raptor-triple-fog-light-kit-w-rigid-industries-d-series/
Baja Designs Kits (Starting at $769): http://www.4x4truckleds.com/2017-ford-raptor-triple-fog-light-kit-w-baja-designs-lights/
FastEddie
My local shop ordered some brackets and harnesses from you guys for me. It won't be for awhile until I can get in there, but I look forward to seeing how this all fits in and works.
4x4TruckLEDs.com
4x4TruckLEDs.com
Awesome. They'll have the brackets tomorrow (if it's the one in NJ i saw the order come in). You'll love them and so will the shop, as they are real easy to install. Plus the wiring harness we give you is great. It's one harness with all your connections. Super simple.
4x4TruckLEDs.com
4x4TruckLEDs.com
Carlos wasn't happy with his Rigid Radiance lights, or his old bezel, so he upgraded his lighting to some Baja Designs Pros and our SPP Triple Fog Light Kit. Now he can finally see at night!
These kits are available with any combination of Baja Designs and Rigid D-Series you can think up. We also have them with the Rigid Radiance if you want that cool amber backlight feature (or any other color).
Each kit includes our custom made, all-in-1 wiring harness allowing you control of your lights from 3 upfitters.
The bracket are made in America, powder coated black and include stainless steel hardware.
Brackets Only: http://www.4x4truckleds.com/2017-ford-raptor-triple-fog-light-brackets/
Baja Designs Kit: http://www.4x4truckleds.com/2017-ford-raptor-triple-fog-light-kit-w-baja-designs-lights/
Rigid D-Series Kit: http://www.4x4truckleds.com/2017-ford-raptor-triple-fog-light-kit-w-rigid-industries-d-series/
Rigid Radiance Kit: http://www.4x4truckleds.com/2017-ford-raptor-triple-fog-light-kit-w-rigid-industries-radiance-pods/
