Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Lighting Modifications Forum [GEN 1]
Rigid Industries :: A-Series :: Rock Light Kits
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="RigidIndustries" data-source="post: 894411" data-attributes="member: 7614"><p>[ATTACH=full]247717[/ATTACH]</p><p></p><p><strong>Rigid Industries | <span style="color: #ff0000">A-Series :: Rock Light Kits</span></strong></p><p><strong><span style="color: #ff0000"></span></strong></p><p>One of our most popular lights with its small size and wide range of uses.</p><p></p><p><strong>A-Series LED Lights</strong> - These little lights pack quite a punch with unparalleled brightness and efficiency. Available in two options High or Low power, the A-Series is extremely versatile. Whether it's used as a dome light in your truck, a deck light on your boat, or driving lights on your trailer, the A-Series is the perfect solution for all your needs. The A-Series includes multiple mounting options and is available in multiple LED colors - red, blue, green, and three shades of white to suit your needs.</p><p></p><p>[ATTACH=full]247718[/ATTACH]</p><p></p><p><strong><a href="http://bit.ly/rigid_a-series_specs" target="_blank">A-SERIES FULL SPECS HERE</a></strong></p><p></p><p><strong>A-Series Rock Light Kits -</strong> Whether you are rock crawling, leading the trails of Moab or riding the dunes at night, the high power A-Series LED lights with 15’ leads, custom angled mounting pads, 8’ wiring harness and a distribution block to make for the perfect and indestructible lighting kit.</p><p></p><p><strong><a href="http://bit.ly/rigidrocklightkits" target="_blank">4-Rock Light Kit </a></strong></p><p>[ATTACH=full]247719[/ATTACH]</p><p><strong>Features: </strong></p><ul> <li data-xf-list-type="ul">4 A-Series LED Lights (with 15' leads)</li> <li data-xf-list-type="ul">Color: Cool White</li> <li data-xf-list-type="ul">Includes: Wire Harness (Customizable for use on Jeep/Truck or Trailer)</li> </ul><p><strong>Specifications: </strong></p><ul> <li data-xf-list-type="ul">Watts: 16W</li> <li data-xf-list-type="ul">Amp Draw: 1.2A</li> <li data-xf-list-type="ul">LED's: 12</li> <li data-xf-list-type="ul">Raw Lumens: 1600</li> <li data-xf-list-type="ul">Voltage: 10-28V</li> </ul><p></p><p><strong><a href="http://bit.ly/rigidrocklightkits" target="_blank">6-Rock Light Kit</a></strong></p><p>[ATTACH=full]247720[/ATTACH]</p><p><strong>Features:</strong></p><ul> <li data-xf-list-type="ul">6 A-Series LED Lights (with 15' leads)</li> <li data-xf-list-type="ul">Color: Cool White</li> <li data-xf-list-type="ul">Includes: Wire Harness (Customizable for use on Jeep/Truck or Trailer)</li> </ul><p><strong>Specifications: </strong></p><ul> <li data-xf-list-type="ul">Watts: 24</li> <li data-xf-list-type="ul">Amp Draw: 1.8A</li> <li data-xf-list-type="ul">LED's: 18</li> <li data-xf-list-type="ul">Raw Lumens: 2400</li> <li data-xf-list-type="ul">Voltage: 10-28V</li> </ul><p></p><p></p><p><strong>Check out our entire line up of A-Series lights and kits here:</strong></p><p><a href="http://bit.ly/rigid_a-series" target="_blank"><strong>Rigid Industries A-Series LED Lights</strong></a></p><p></p><p><strong>Already have one of our kits installed?</strong></p><p><strong><span style="color: #ff0000">Share your photos for a chance to win some free swag!</span></strong></p><p><strong><span style="color: #ff0000"></span></strong></p><p><em><span style="color: #808080">Also, be sure to check with your favorite Rigid dealer for availability!</span></em></p></blockquote><p></p>
[QUOTE="RigidIndustries, post: 894411, member: 7614"] [ATTACH=full]247717[/ATTACH] [B]Rigid Industries | [COLOR=#ff0000]A-Series :: Rock Light Kits [/COLOR][/B] One of our most popular lights with its small size and wide range of uses. [B]A-Series LED Lights[/B] - These little lights pack quite a punch with unparalleled brightness and efficiency. Available in two options High or Low power, the A-Series is extremely versatile. Whether it's used as a dome light in your truck, a deck light on your boat, or driving lights on your trailer, the A-Series is the perfect solution for all your needs. The A-Series includes multiple mounting options and is available in multiple LED colors - red, blue, green, and three shades of white to suit your needs. [ATTACH=full]247718[/ATTACH] [B][URL='http://bit.ly/rigid_a-series_specs']A-SERIES FULL SPECS HERE[/URL][/B] [B]A-Series Rock Light Kits -[/B] Whether you are rock crawling, leading the trails of Moab or riding the dunes at night, the high power A-Series LED lights with 15’ leads, custom angled mounting pads, 8’ wiring harness and a distribution block to make for the perfect and indestructible lighting kit. [B][URL='http://bit.ly/rigidrocklightkits']4-Rock Light Kit [/URL][/B] [ATTACH=full]247719[/ATTACH] [B]Features: [/B] [LIST] [*]4 A-Series LED Lights (with 15' leads) [*]Color: Cool White [*]Includes: Wire Harness (Customizable for use on Jeep/Truck or Trailer) [/LIST] [B]Specifications: [/B] [LIST] [*]Watts: 16W [*]Amp Draw: 1.2A [*]LED's: 12 [*]Raw Lumens: 1600 [*]Voltage: 10-28V [/LIST] [B][URL='http://bit.ly/rigidrocklightkits']6-Rock Light Kit[/URL][/B] [ATTACH=full]247720[/ATTACH] [B]Features:[/B] [LIST] [*]6 A-Series LED Lights (with 15' leads) [*]Color: Cool White [*]Includes: Wire Harness (Customizable for use on Jeep/Truck or Trailer) [/LIST] [B]Specifications: [/B] [LIST] [*]Watts: 24 [*]Amp Draw: 1.8A [*]LED's: 18 [*]Raw Lumens: 2400 [*]Voltage: 10-28V [/LIST] [B]Check out our entire line up of A-Series lights and kits here:[/B] [URL='http://bit.ly/rigid_a-series'][B]Rigid Industries A-Series LED Lights[/B][/URL] [B]Already have one of our kits installed? [COLOR=#ff0000]Share your photos for a chance to win some free swag! [/COLOR][/B] [I][COLOR=#808080]Also, be sure to check with your favorite Rigid dealer for availability![/COLOR][/I] [/QUOTE]
Insert quotes…
Verification
Post reply
Staff online
Big Blue
Administrator
Members online
k2damax
Big Blue
pat247
Hambone
Badboy4fun_wa
Zeusmotorworks
93,423
56,706
marquez47
Forums
Accept
Learn more…
