Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 2 (2017-2020) Ford F-150 Raptor Forums
Ford Raptor Suspension Discussion and Modification
Retorque lca shock bolt
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="mAtTyG04" data-source="post: 1568676" data-attributes="member: 40270"><p>Fixed! Brought it to a local off road shop. He re torqued the lower shock bolt to 450lbs while at full droop. He also notice the brake pad clip loose and a layer of coating was worn of. He tightened it and greased it up. For good measure he re-torqued the LCA's and UCA's. He recommended I go to dealer and get the clips replaced by warranty. I was charged 2hrs shop time but drove away with the truck as quiet as the day I got it so worth every cent!</p></blockquote><p></p>
[QUOTE="mAtTyG04, post: 1568676, member: 40270"] Fixed! Brought it to a local off road shop. He re torqued the lower shock bolt to 450lbs while at full droop. He also notice the brake pad clip loose and a layer of coating was worn of. He tightened it and greased it up. For good measure he re-torqued the LCA's and UCA's. He recommended I go to dealer and get the clips replaced by warranty. I was charged 2hrs shop time but drove away with the truck as quiet as the day I got it so worth every cent! [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
Gumby
k3k0a808
grleon65
ToadSmasher2K1
Gdog
Raptorman19
Karter01
FmaxTurboSi
EasyDoesIt
jdm_sixtwo
dsg2003mach1
flyitaway
karna
mprice1234
Oaktree202
HTXShadow
FGHT ON
jekyll537
Turning Blue
Hburgrap
Oldfart
BHook
MurderedOutSVT
QCRappy
bmiracle
WA2012
mubz64
PolarZ
ST3V3LU1S
Ryan Voight
nikhsub1
jond
kweli19
James O
ksgries
stevelp99
dwood
Stingray23
muss3r86
GCATX
Spydie35
997
BigSkyGuy
Whoops
Jeff Oldham
martinjoa
Ryed
flips1985
HipHopHonky
ljn21
... and 54 more.
93,254
56,548
nadz88
Forums
Accept
Learn more…
