Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford SVT Raptor General Discussions [GEN 1]
Pads and rotors...baby Jesus help me.
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="caisaacson" data-source="post: 809483" data-attributes="member: 13515"><p>I received my r1 concepts brake pads and rotors today so naturally I decided to skip work and install them. </p><p></p><p>3 hours later, the passenger side is perfect but something is not right in the drivers side. As soon as I got back from the test drive I could smell unmistakeable smell of brakes coming from the drivers side wheel well. In addition to the smell, the rotor got so hot that it blued itself.</p><p></p><p>Ok so what could I have missed? I broke the drivers side down and checked everything. Pads had an ode pattern on them and the rotor was hot and dis colored but I found no obvious cause. </p><p></p><p>Fast forward, I put everything back together, test drove it again, but same results.</p><p></p><p>Who in this wide world of raptor owners can shed some light on this?</p><p></p><p>Side note: I put a thermal cam on both rotors following the second test drive. Drivers side was 200 degrees or more and passenger was 130-140. What temps are brakes rated for?</p><p></p><p></p><p>Sent from my iPhone using Tapatalk</p></blockquote><p></p>
[QUOTE="caisaacson, post: 809483, member: 13515"] I received my r1 concepts brake pads and rotors today so naturally I decided to skip work and install them. 3 hours later, the passenger side is perfect but something is not right in the drivers side. As soon as I got back from the test drive I could smell unmistakeable smell of brakes coming from the drivers side wheel well. In addition to the smell, the rotor got so hot that it blued itself. Ok so what could I have missed? I broke the drivers side down and checked everything. Pads had an ode pattern on them and the rotor was hot and dis colored but I found no obvious cause. Fast forward, I put everything back together, test drove it again, but same results. Who in this wide world of raptor owners can shed some light on this? Side note: I put a thermal cam on both rotors following the second test drive. Drivers side was 200 degrees or more and passenger was 130-140. What temps are brakes rated for? Sent from my iPhone using Tapatalk [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
brunorulez
alockbox
elpechedepeche
shigman
dvm
rp2024
RBain75
BushwiickBill
Dbone
JD05
RCorsa
raptordawg08
topher1130
Nesc204
Crywolf4
CRchs1
GCATX
Zeusmotorworks
Gsteve
Digipax
new raptor
roger7254
Morrisabm
tcm glx
Diverdown3
Seven Twenty
Cornwallis
RaptorFun
akbjr
kocher93
ToadSmasher2K1
dfw62
WhiskeyTangoGTFO
2010 Shelby
HOLLYWOOD 1
daveol123
HORN HIGH ACES
Helopilot
nltruck
VJDWashington
Mc5601
MurderedOutSVT
WTX
Xerxes
jm77
dmb359
ktide09
WRX2RAPTOR
MCM34
nickloms
... and 17 more.
93,349
56,632
mtphun
Forums
Accept
Learn more…
