Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 2 (2017-2020) Ford F-150 Raptor Forums
Ford Raptor Suspension Discussion and Modification
- offset wheels ful compression fender questions
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="TXRaptor" data-source="post: 1307095" data-attributes="member: 181"><p>To do a proper calculation on how far they will stick out past the factory wheels, you need to included the width of the wheel along with the offset.</p><p></p><p>Factory wheels are 17x8.5 with a +34mm offset.</p><p>The same width wheel with a -15 offset will stick out (34+15) 49mm or 1.93" further than the factory wheels.</p><p></p><p>As mentioned above, 35" tires on 8.5" wheels that stick out almost 2" more than factory will rub at full compression.</p></blockquote><p></p>
[QUOTE="TXRaptor, post: 1307095, member: 181"] To do a proper calculation on how far they will stick out past the factory wheels, you need to included the width of the wheel along with the offset. Factory wheels are 17x8.5 with a +34mm offset. The same width wheel with a -15 offset will stick out (34+15) 49mm or 1.93" further than the factory wheels. As mentioned above, 35" tires on 8.5" wheels that stick out almost 2" more than factory will rub at full compression. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
P4SHOCAT
blademan
jsigone
Reptar854
GordoJay
SuperDutyKev67
BigBlue20
DaveInMn
BlueHound
mleaky
Lunatik Logan
Pacific Wheel
vill
riv
ToadSmasher2K1
braptr
smteal
isis
Sharpie69
Zeke555
Cronn99
RogueClimber
Nick@GotExhaust
WC114
FP Forged
New recaros
Winchester30
swirly
Noplacelikeloam
TremorRaptor
MrB78
TiFJ
Gumby
sf2360
Josfue
daddyd
Mrjoshiba
raptorstyle85
DFS
Pnwrider
smgilles
MurderedOutSVT
CruiserClass
10SpdsOfFury
ryeabs
OICNW-Rob
RdR2027
northlaker
lawyerup
kandewinn
... and 20 more.
93,660
56,965
Waldo3oh3
Forums
Accept
Learn more…
