Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford SVT Raptor General Discussions [GEN 1]
Lead Frame Dealer Screw Up !
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="EvilMfg" data-source="post: 1706903" data-attributes="member: 28946"><p>The lead frame was actually installed incorrectly. Two points here would be that they need to make sure the have the plug fastened properly to the lead frame output and then inside the transmission there is a plastic piece that attaches to the lead frame. If this piece is not installed in the correct location, the transmission will not shift. I have seen this issue twice out of the 10 or so lead frames we have replaced. Both times the tech did not have this plastic slide piece in the right location...</p></blockquote><p></p>
[QUOTE="EvilMfg, post: 1706903, member: 28946"] The lead frame was actually installed incorrectly. Two points here would be that they need to make sure the have the plug fastened properly to the lead frame output and then inside the transmission there is a plastic piece that attaches to the lead frame. If this piece is not installed in the correct location, the transmission will not shift. I have seen this issue twice out of the 10 or so lead frames we have replaced. Both times the tech did not have this plastic slide piece in the right location... [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
kknyrass
FP_RPTR
Raptor513
rino
LibertyDNP
salguzman517
Telecaster480
Pismobound
khildebr
mattl600
mprice1234
EliteAGDan
MSP
Staticroof
DaveInMn
pirates1456
nelsonr103
ToadSmasher2K1
Brad_hartpro
Stingray23
Admin.RealTruck
10SpdsOfFury
Ryan C
Barak
RaptorAddict1
Ziggy2023
SeasickLI
Budget1
RaptorJoe331
ln13ln13
CessnaDriver
jekyll537
OBXRAPTOR17
Azurebeast
Jakenbake
Current
BBR
daytona1783
jond
Braaaaptor
NickyF25
ohhcho
BoostCreep
Coyote_695
navy2x
Russ103
BamaFun
sukid
alibo70
Prormk
... and 19 more.
93,186
56,468
ngodavid23
Forums
Accept
Learn more…
