Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
Ford Raptor Forums - General Information
Ford Raptor Problems and Questions Forum
Integrated Trailer Brake Control Problem
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="FSM06" data-source="post: 8858" data-attributes="member: 77"><p>That's a tough one Batman. My first impression as I read your story was that there was definitely a concern in the trailer wiring on the trailer until you stated that it worked fine on another truck. I assume you are using the large 7-pin connector on both trucks since you said the trailer brakes are being used. I would start by using a trailer simulator (small device made by several companies that plugs into your recepticle and lights according to what is being used.....they are not very expensive and pay for themselves in a hurry) on both trucks and see what type of result you get. Only thing that comes to mind is a possible short to B+ in the truck wiring to the recepticle causing voltage to be supplied to the trailer brakes. When the message center displays "trailer wiring fault" keep in mind that it does not know where the plug is, "trailer wiring" includes everything from the trailer brake controller module to the trailer.</p><p></p><p>Keep me posted, as I will be interested to see what you find.</p><p></p><p>FSM</p></blockquote><p></p>
[QUOTE="FSM06, post: 8858, member: 77"] That's a tough one Batman. My first impression as I read your story was that there was definitely a concern in the trailer wiring on the trailer until you stated that it worked fine on another truck. I assume you are using the large 7-pin connector on both trucks since you said the trailer brakes are being used. I would start by using a trailer simulator (small device made by several companies that plugs into your recepticle and lights according to what is being used.....they are not very expensive and pay for themselves in a hurry) on both trucks and see what type of result you get. Only thing that comes to mind is a possible short to B+ in the truck wiring to the recepticle causing voltage to be supplied to the trailer brakes. When the message center displays "trailer wiring fault" keep in mind that it does not know where the plug is, "trailer wiring" includes everything from the trailer brake controller module to the trailer. Keep me posted, as I will be interested to see what you find. FSM [/QUOTE]
Insert quotes…
Verification
Post reply
Staff online
Griffin
Administrator
Members online
julien194b
Dave T
ToadSmasher2K1
sofloraptor
BadWRP
HuffRanch
monzac
US HWY 666
Cornwallis
BBR
RaptorFan1988
Hard R
IDI-Charlie
caseyhuxta
james9
elking
stevenstommyboy1
someday
Geforce
Hal993
Burt
James O
JD05
CecilK12
Chzhead
06z
Bubba0612
DFS
Oldfart
NickyF25
Coyote_695
dfranks
Tomkirkland4
SeasickLI
soheilmos
scottp6188
new raptor
nikhsub1
MurderedOutSVT
sct
DRC3
Dudebrodude
Jeremy K
Rustyseatbelt
Griffin
JHughes629
Nyamg
Ol_Blue
Goose8651
... and 37 more.
93,311
56,603
Randigitty
Forums
Accept
Learn more…
