Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 2 (2017-2020) Ford F-150 Raptor Forums
Ford Raptor Lighting Forum [GEN 2]
Help with wiring Rigid 20" E-Series Light Bar
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="DaveT" data-source="post: 1516404" data-attributes="member: 35482"><p>I blew two 15 Amp Fuses. The installation guide says the "minimum fusing requirement" is 15 Amps for the E-series (20"+). The specs from RI do shoe 15.3 Amps max draw, so I would assume it's peaking over 15 Amp when it gets lit up and the buffer of the larger fuse is enough? </p><p></p><p>I only have the lightbar on this Aux switch.</p></blockquote><p></p>
[QUOTE="DaveT, post: 1516404, member: 35482"] I blew two 15 Amp Fuses. The installation guide says the "minimum fusing requirement" is 15 Amps for the E-series (20"+). The specs from RI do shoe 15.3 Amps max draw, so I would assume it's peaking over 15 Amp when it gets lit up and the buffer of the larger fuse is enough? I only have the lightbar on this Aux switch. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
blueherron96
MurderedOutSVT
Duane R
DrBro
OEMPlus Raptor
Sever18
Rekkr
Dano182
cgriffin602
EricM
tcm glx
SpineRaptor
RaptorEnjoyoer
Jojo17
Jarod7504
Reptar854
AtlEcoboost
Five0Raptor
RaptorMach3p5
06z
Trick99
Nesc204
NinjaRaptor
Cornwallis
davidjohns0n
clvtch
Sage
Sergio212
CleverGirl_
nicewaptor
Nick@Apollo-Optics
Txrigg
darr3239
Bozz
petlh
tank_jh
LANUTZ
spizike9
SeasickLI
Sonicsunspot
sjordan18
herbie216
Showdub
Locker1
Lifted&slifted
BoostCreep
GordoJay
BLEEKER
itsrichierich
Pokhj
... and 137 more.
93,211
56,495
bolilly
Forums
Accept
Learn more…
