H3R Performance Fire Extinguisher Seat Mount
Slacker
Alexandria, VA
I have had fire extinguishers stuffed into holes and under seats for a while. I spotted an interesting mount in the 4 Wheel Parts Offroad Adventure mag I got last week and decided to give it a try. Made by H3R Performance, I ordered the mount from Summit Racing. It arrived yesterday and like always I was installing it about 47 seconds after the FedEx guy left.
There are only 8 parts plus screws to putting it all together was pretty easy. I ended up using the base, both long extension arms and one of the smaller L brackets for the install.
I had to remove the door side of the seat plastic to get to the metal where I drilled a hole. On this (door) side I only used this hole and the long extension arm. No L bracket needed as this hole is pretty close to strait in line with the extension arm.
The other side I had to bend the L bracket a little as the console side of the seat has a curved metal piece on the front. To connect that side I used the extension arm and the modified L bracket. The result is a clean install that moves with the seat and is rock solid.
I haven't beaten it off-road yet but it sure seems sturdy enough to not come apart. The extinguisher is always going to be right where I left it, ready to use when needed.
