Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Audio/Video/Electronics Forum [GEN 1]
Ford Sync
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="jethelopilot" data-source="post: 504323" data-attributes="member: 10962"><p><strong>V3.6 MyFord Touch Firmware Update</strong></p><p></p><p>Got the email from Ford this afternoon about the new MyFord Touch firmware update 3.6. Figured I better get it while the get’n was good—and go-ahead right then and do the update. (BTW, the site seems to be overloaded now. I would maybe wait a day or two before you try.)</p><p></p><p>It was absolutely straight-forward—just followed the website screen instructions. You’ll need a 2GB USB thumbdrive for the download and install.</p><p></p><p>Went out and started up truck and then put the thumbdrive into the top USB slot. The system started the update process after about a 5-10 second delay with a opening warning screen about not shutting off your truck and trying to do it with Accessory power; quitting halfway thru it; and some other instructions.</p><p></p><p>It took about 30 minutes to do the update. The systems shuts down and reboots half-a-dozen times during the process. I just sat in my driveway with my iPad, surfed and waited until it was completely finished. When it is done it has you go back to the web site to report a successful install with the thumbdrive you used for the install.</p><p></p><p>It was straight-forward and no issues.</p><p></p><p>Here’s what I noticed:</p><p></p><p>Everything Ford says it will do it does, which is nice!</p><p></p><p>They fixed the Wifi password issue (previously you could not enter any combo of alpha-numerics for password to your home WiFi). SO now you can connec the truck to your WiFi; AND make the truck a access point for other internet access devices.</p><p></p><p>It does appear to run faster and transition smoother.</p><p></p><p>Voice commands are still a bit tricky.</p><p></p><p>It doesn’t erase your SVT “Raptor” opening/closing—which I was worried it might.</p><p></p><p>You keep all of your audio settings including presets.</p><p></p><p>You will have to re-connect your Bluetooth phone and re-enter any quick-dial locations with numbers.</p><p></p><p>You will have to re-select the 911 assist if you had that option selected before.</p><p></p><p>The rear camera looks a bit different and the options for viewing are singular. Delayed or not are still options.</p><p></p><p>Your home location is messed up—at least mine was. It was still listed as a favorite, but when I told the system to “Navigation, Destination, Home.” It said that I needed to set my home location (which is how I knew it was still there as I checked). I just erased it and re-inputed it—worked fine. I asked it to navigate to a couple of my Favorites and it seemed to be working fine.</p><p></p><p>The clock settings get re-set to default. I had mine on military time and it was reset to standard. Plus it was one hour behind (missed the Daylight savings change?) Easily fixed of course and working good now.</p><p></p><p>All-in-all I think worth the time and no issues with physical part of the update.</p><p></p><p>Just MHO.</p><p></p><p>Thanks!</p></blockquote><p></p>
[QUOTE="jethelopilot, post: 504323, member: 10962"] [b]V3.6 MyFord Touch Firmware Update[/b] Got the email from Ford this afternoon about the new MyFord Touch firmware update 3.6. Figured I better get it while the get’n was good—and go-ahead right then and do the update. (BTW, the site seems to be overloaded now. I would maybe wait a day or two before you try.) It was absolutely straight-forward—just followed the website screen instructions. You’ll need a 2GB USB thumbdrive for the download and install. Went out and started up truck and then put the thumbdrive into the top USB slot. The system started the update process after about a 5-10 second delay with a opening warning screen about not shutting off your truck and trying to do it with Accessory power; quitting halfway thru it; and some other instructions. It took about 30 minutes to do the update. The systems shuts down and reboots half-a-dozen times during the process. I just sat in my driveway with my iPad, surfed and waited until it was completely finished. When it is done it has you go back to the web site to report a successful install with the thumbdrive you used for the install. It was straight-forward and no issues. Here’s what I noticed: Everything Ford says it will do it does, which is nice! They fixed the Wifi password issue (previously you could not enter any combo of alpha-numerics for password to your home WiFi). SO now you can connec the truck to your WiFi; AND make the truck a access point for other internet access devices. It does appear to run faster and transition smoother. Voice commands are still a bit tricky. It doesn’t erase your SVT “Raptor” opening/closing—which I was worried it might. You keep all of your audio settings including presets. You will have to re-connect your Bluetooth phone and re-enter any quick-dial locations with numbers. You will have to re-select the 911 assist if you had that option selected before. The rear camera looks a bit different and the options for viewing are singular. Delayed or not are still options. Your home location is messed up—at least mine was. It was still listed as a favorite, but when I told the system to “Navigation, Destination, Home.” It said that I needed to set my home location (which is how I knew it was still there as I checked). I just erased it and re-inputed it—worked fine. I asked it to navigate to a couple of my Favorites and it seemed to be working fine. The clock settings get re-set to default. I had mine on military time and it was reset to standard. Plus it was one hour behind (missed the Daylight savings change?) Easily fixed of course and working good now. All-in-all I think worth the time and no issues with physical part of the update. Just MHO. Thanks! [/QUOTE]
Insert quotes…
Verification
Post reply
Staff online
Big Blue
Administrator
Members online
MajorAR
leader32
ograptor
mattl600
jAKe47
mike1307
EODbmg17
kandewinn
Big Green
stevenstommyboy1
Bozz
ScottS23
got2fly
Avalanche24
Big Blue
pat247
Pikser
Freedom Roamers
jdm_sixtwo
Kdubdakar
fordfreek
grussell
SlickTrick
MidnightSpecial
stoppard stop
Alamoraptor
james9
NACHOMASTER
mprice1234
nniezgor
Turbo_lander
Achilles
Zeusmotorworks
93,478
56,762
jhook
Forums
Ford Sync
Accept
Learn more…
