Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 3 (2021+) Ford F-150 Raptor Forums
Ford F-150 Raptor General Discussions [GEN 3]
Drive mode not avaialable"
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="tm965" data-source="post: 1943996" data-attributes="member: 48689"><p>if you have forscan do a ride height recal. if not, try putting it in ET (engineering and test mode)--find a level surface, put the car in neutral and then hit the m (manual button) while the truck is on. turn the vehicle off. then hit the start button with your foot off the gas so it doesnt start, then immediately floor the gas pedal 3x and you should see an ET symbol pop up in the bottom right corner of the dash. let it sit a few sec and you should be good to go (assuming you dont have a ***** wire to some of the other posters points above). I had this happen to me in the last month after a small jump. when i restarted the truck a bit later, the notification came up and my suspension was full stiff. immediately did ET and when i restarted the truck next the problem was gone.</p></blockquote><p></p>
[QUOTE="tm965, post: 1943996, member: 48689"] if you have forscan do a ride height recal. if not, try putting it in ET (engineering and test mode)--find a level surface, put the car in neutral and then hit the m (manual button) while the truck is on. turn the vehicle off. then hit the start button with your foot off the gas so it doesnt start, then immediately floor the gas pedal 3x and you should see an ET symbol pop up in the bottom right corner of the dash. let it sit a few sec and you should be good to go (assuming you dont have a ***** wire to some of the other posters points above). I had this happen to me in the last month after a small jump. when i restarted the truck a bit later, the notification came up and my suspension was full stiff. immediately did ET and when i restarted the truck next the problem was gone. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
jtschratz
dfranks
RRR19-Mike
Jay_P
SeasickLI
WMRaptor
ricetuna
maraim20
Gumby
DFS
Specialtyperformanceparts
Psirus7
pirates1456
zefen
MajorAR
grleon65
tunafish raptor
JDMCTR00
fastford4x4
Braves Fan
dmb359
John813
NJ2020
ModCo Wheels
RogueClimber
77Raptor
HAP
IHAVETWO
ss55539
mobob
Frogger22
CruiserClass
Mike27t
Q Ballz83
Jmbeebe0722
WhiskeyTangoGTFO
Dev
FP Forged
hsoonalmulla
Frofan
OffroadAlliance.com
Latchkey Kid
JD05
Bozz
tonythis
Dantana619
james9
isis
Sparda1123
tm965
... and 54 more.
93,588
56,869
macbasso
Forums
Accept
Learn more…
