Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Suspension Discussion and Modification
Dead horse has some questions
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Maxx2893" data-source="post: 685171" data-attributes="member: 1161"><p>1. Possibly, however I have not seen it. Top perch does for sure but from everything I have seen, mid perch is perfectly fine for it. </p><p></p><p>2. Close, but no. You lose about and 1.5" of droop (down) travel, but you gain that in bump (up) travel. The total travel still cycles at the same length, ride height is just shifted to a different point in that total travel. </p><p></p><p>3. This is what I've heard. Unfortunately nobody has solid, concrete, undeniable evidence towards or against this theory. Yes Mr. Hameedi claims this is not true, but I would guess he is required to make this claim. </p><p></p><p>4. Not that I can tell. The ride does firm up slightly, however I don't see this as a negative. It's a nice change and still rides plenty softly. On a positive note, the slight increase in stiffness does majorly reduce nose dive when coming to a stop. It will raise the truck slightly so that could be a negative if you have clearance issues on stock perch. That's unique to the end user though.</p></blockquote><p></p>
[QUOTE="Maxx2893, post: 685171, member: 1161"] 1. Possibly, however I have not seen it. Top perch does for sure but from everything I have seen, mid perch is perfectly fine for it. 2. Close, but no. You lose about and 1.5" of droop (down) travel, but you gain that in bump (up) travel. The total travel still cycles at the same length, ride height is just shifted to a different point in that total travel. 3. This is what I've heard. Unfortunately nobody has solid, concrete, undeniable evidence towards or against this theory. Yes Mr. Hameedi claims this is not true, but I would guess he is required to make this claim. 4. Not that I can tell. The ride does firm up slightly, however I don't see this as a negative. It's a nice change and still rides plenty softly. On a positive note, the slight increase in stiffness does majorly reduce nose dive when coming to a stop. It will raise the truck slightly so that could be a negative if you have clearance issues on stock perch. That's unique to the end user though. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
Bmwtech113
dmb359
chizzleknizzle
TheButcher
Raptor King
rkwjunior
CleverGirl_
pirates1456
olverac
Venti Raptor
mobob
mgbond12
nealhoney
modraptor
thatJeepguy
Digipax
james9
WNCHSTR96
mike1307
cfmistry
Jayden
Latchkey Kid
RAPTORHD
dsg2003mach1
MFouts
goodboyralph
mattncsu
hsoonalmulla
Original Bronco
MtopRaptor
Dan H
FreightTerrain
ToadSmasher2K1
Achilles
dvm
23f150
Old-Raptor-guy
Budget1
Wim
BP31
jAKe47
SuprSeb
Rekkr
Zeusmotorworks
blazn5667
RaptorSS
julien194b
... and 2 more.
93,363
56,644
LDMiles
Forums
Accept
Learn more…
