Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
Ford Raptor Forums - General Information
Ford Raptor Problems and Questions Forum
Coolant tank & Vacuum line
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="gatorfan462" data-source="post: 1412550" data-attributes="member: 37902"><p>I just picked up a 2010 Raptor yesterday morning. Drove it home 40 miles and then later on we went to go watch some collage football at a friends house. So we stopped by a grocery store to grab a few things and on my way out to the truck I noticed a puddle under the truck. It was a clear liquid like water and didn't have a oily texture to it or a smell that I could smell. Went to my friends house couldn't see the leak anywhere. Had to leave to go check on the dogs that we left at home and on my way there the check brake system light came on as well as the traction control light, e-brake light and hill descent fault. I'm suppose to take it back tomorrow and have the dealer look at it but I was outside looking around and found a plug for the brake booster that has 2 vacuum ports under it that don't have lines attached. And I line nearby that has a screw in the end of it to cap it off. I checked the rear wheels speed sensors and they appear to be fine and I don't think there is any water in the 3 brake light, which is what I normally see being the cause of this issue. And I believe the puddle under the truck came from the coolant tank, the little ball hinge piece that the cap is connected to that keeps it attached when you open the cap appears to be leaking. There is also some sludge like material in the coolant tank, should I be alarmed by that?</p><p></p><p>I have pictures to post of the vacuum lines and where I believe the leak is on the coolant tank is, as well as some sludge on my finger. What should these vacuum lines be attached to and is the part I think is leaking look like its not seated all the way down? </p><p></p><p> [ATTACH=full]132233[/ATTACH] [ATTACH=full]132234[/ATTACH] [ATTACH=full]132235[/ATTACH] [ATTACH=full]132236[/ATTACH]</p></blockquote><p></p>
[QUOTE="gatorfan462, post: 1412550, member: 37902"] I just picked up a 2010 Raptor yesterday morning. Drove it home 40 miles and then later on we went to go watch some collage football at a friends house. So we stopped by a grocery store to grab a few things and on my way out to the truck I noticed a puddle under the truck. It was a clear liquid like water and didn't have a oily texture to it or a smell that I could smell. Went to my friends house couldn't see the leak anywhere. Had to leave to go check on the dogs that we left at home and on my way there the check brake system light came on as well as the traction control light, e-brake light and hill descent fault. I'm suppose to take it back tomorrow and have the dealer look at it but I was outside looking around and found a plug for the brake booster that has 2 vacuum ports under it that don't have lines attached. And I line nearby that has a screw in the end of it to cap it off. I checked the rear wheels speed sensors and they appear to be fine and I don't think there is any water in the 3 brake light, which is what I normally see being the cause of this issue. And I believe the puddle under the truck came from the coolant tank, the little ball hinge piece that the cap is connected to that keeps it attached when you open the cap appears to be leaking. There is also some sludge like material in the coolant tank, should I be alarmed by that? I have pictures to post of the vacuum lines and where I believe the leak is on the coolant tank is, as well as some sludge on my finger. What should these vacuum lines be attached to and is the part I think is leaking look like its not seated all the way down? [ATTACH=full]132233[/ATTACH] [ATTACH=full]132234[/ATTACH] [ATTACH=full]132235[/ATTACH] [ATTACH=full]132236[/ATTACH] [/QUOTE]
Insert quotes…
Verification
Post reply
Staff online
Griffin
Administrator
Members online
jprovence
Azurebeast
tabvette
EliteAGDan
dsa6953
OEMPlus Raptor
Evil Peaches
raptorgroyper
kirkb
HighSpeedLowDrag
TomDirt
ToadSmasher2K1
Butterz
Irregular F150
RaptorFan1988
MDJAK
grleon65
Winchester30
kylesatx
Telecaster480
Booth9999
DavidL
mashtastic
CruiserClass
mglane83
Zach Gen3
06z
jrotelle
julien194b
mprice1234
quattrojim
James O
Rptrrob702
mleaky
flyitaway
salguzman517
james9
johnnyutah
Jhollowell
shank_guru
PK37
Turning Blue
Fireman Dave
LOUSCRW
SeasickLI
Justbob
cfmistry
MarkOne
Noplacelikeloam
Griffin
... and 36 more.
93,253
56,547
nadz88
Forums
Accept
Learn more…
