Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford SVT Raptor General Discussions [GEN 1]
Binding or tightness in steering
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="agdaniels" data-source="post: 1436357" data-attributes="member: 5384"><p>Recently purchased a '14 and the steering hasn't been right since I got it. Figured the steering pump was going because the fluid was milky and stunk, and it was tough to turn. Mix in some grittiness and I figured it was time.</p><p></p><p>Pump and fluid changed, no more grittiness, but still hard to turn and slow to return to center as if the steering shaft is bound up. Happens driving or sitting still. Sitting still the pump is working real hard to turn, even makes the RPMs (and gas gauge) dip.</p><p></p><p>I figured I would grease up the intermediate steering shaft and see if that helps, and get an alignment to check caster. But does anyone else have any experience with this? Don't want to burn up my new pump from whatever is causing all that tension in the steering. </p><p></p><p>Appreciate any thoughts, hate to throw money at a problem on the wrong parts</p></blockquote><p></p>
[QUOTE="agdaniels, post: 1436357, member: 5384"] Recently purchased a '14 and the steering hasn't been right since I got it. Figured the steering pump was going because the fluid was milky and stunk, and it was tough to turn. Mix in some grittiness and I figured it was time. Pump and fluid changed, no more grittiness, but still hard to turn and slow to return to center as if the steering shaft is bound up. Happens driving or sitting still. Sitting still the pump is working real hard to turn, even makes the RPMs (and gas gauge) dip. I figured I would grease up the intermediate steering shaft and see if that helps, and get an alignment to check caster. But does anyone else have any experience with this? Don't want to burn up my new pump from whatever is causing all that tension in the steering. Appreciate any thoughts, hate to throw money at a problem on the wrong parts [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
cfmistry
pander952
pirates1456
MZRaptor72
24NoVARaptor
QCRappy
RaptorMach3p5
alockbox
ljn21
MotoDad
tonythis
Gumby
blazn5667
Badboy4fun_wa
Bozz
Oldfart
juppal
yoxxi
Sozzy12
HTXShadow
Romes86
kevo_lo
Shadow15
Nick@Apollo-Optics
tabvette
Yukon Joe
NickyF25
Smoky18Raptor
Goose8651
loganl86
Wartman
CenCstRptr
OBXRAPTOR17
ST3V3LU1S
TwizzleStix
GCATX
HORN HIGH ACES
22R37
goblues38
npc
IndyRaptor83
TAZRaptor
CecilK12
Luchh224
Rekkr
RCorsa
MuscleHamster89
Drkknght
17baker
... and 38 more.
93,238
56,528
osten100
Forums
Accept
Learn more…
