Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
Ford Raptor Forums - General Information
Ford Raptor Maintenance Forum
Best tire pressure gauge
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="MagicMtnDan" data-source="post: 603682" data-attributes="member: 2768"><p>You want good stuff? Longacre makes great (professional grade) products</p><p></p><p>Tire pressure gauges:</p><p><a href="http://www.longacreracing.com/catalog/catlist.asp?catid=8" target="_blank">Longacre Racing - Online Catalog: Electronic Wheel Scales, Gauges, Pyrometers, Chassis Setup and More!</a></p><p></p><p>How to Choose Your Tire Gauge</p><p> </p><p></p><p>Things to think about when purchasing a quality tire gauge</p><p></p><p>PSI Range ~ The most important decision is to get a gauge that works within the pressure range of the tires that you will be using the gauge on. For example, if you run 30 psi in your tires then you should get a 60 psi gauge. If you run 15 psi then you should get a 30 psi gauge. All tire gauges work best in the middle of their range.</p><p></p><p>PSI Increments ~ PSI increments are another thing to consider when choosing the correct gauge. The finer the increments, the more accurate reading you will get.</p><p></p><p>Digital ~ Digital gauges are great, however the cheaper the sensor the less accurate the gauge is. With these gauges you get what you pay for.</p><p></p><p>Analog ~ Analog gauges are a great unit of measurement for the money. Normally, the bigger the face size the better the gauge is.</p><p></p><p>Face Size ~ The larger the tire gauge the more accurate it is, in most cases.</p><p></p><p>Hose Length ~ Longacre has 2 different hose lengths available, 14" and 17" for those hard to reach areas.</p><p></p><p>Chucks ~ Longacre has a swivel tire chuck and a standard non-swivel tire chuck. The swivel chuck is a very nice way to go. If the hose gets twisted up you can correct it with a swivel chuck</p><p></p><p>Holds Pressure ~ Do you need a gauge that when you check the pressure you can still read it when you pull it off the tire?</p><p></p><p>Bleeds air ~ All Longacre tire gauges will allow you to bleed off air when checking the tire pressure.</p><p></p><p>Protective Bumper ~ All Longacre tire gauges have a protective bumper.</p><p></p><p>GID Face or Backlight ~ Do you race at night or in a poorly lit pit area? If so maybe you need a GID (glow-in-the-dark) analog gauge or even maybe a backlit digital gauge.</p><p></p><p>Liquid Filled ~ Here is the scoop on liquid filled tire gauges. Liquid is used to soften the blow of air pressure when it enters the gauge. Just think, if you have 30 pounds of pressure then you have 30 pounds of pressure blasting the gears inside the gauge. That abrupt movement inside the gauge is what wears them out. However All Longacre tire gauges have a dampening system built into the gauge head that softens the blow of air pressure, therefore helping to protect the gears.</p><p></p><p>Case Included ~ The most important way to keep your gauge accurate is to keep it in a foam lined case. When your gauge is getting bounced around in your tool box while hauling it to the track or getting dropped, it will lose its accuracy. Keep your gauge in a case at all times when possible.</p><p></p><p></p><p>A couple of them on Amazon.com </p><p></p><p>[ATTACH=full]226444[/ATTACH]</p><p>[ame=http://www.amazon.com/Longacre-50347-Digital-Tire-Gauge/dp/B000VB43L0]Amazon.com: Longacre 50347 Digital Tire Gauge: Automotive[/ame]</p><p></p><p>[ATTACH=full]226445[/ATTACH]</p><p>[ame=http://www.amazon.com/Longacre-50402-Deluxe-Glow-Gauge/dp/B000F1YW94]Amazon.com: Longacre 50402 Deluxe Glow Tire Gauge: Automotive[/ame]</p><p></p><p>Check out their other products:</p><p><a href="http://www.longacreracing.com" target="_blank">Longacre Racing: Precision Racing Tools: Electronic Wheel Scales, Gauges, Pyrometers, Chassis Setup and More!</a></p></blockquote><p></p>
[QUOTE="MagicMtnDan, post: 603682, member: 2768"] You want good stuff? Longacre makes great (professional grade) products Tire pressure gauges: [url=http://www.longacreracing.com/catalog/catlist.asp?catid=8]Longacre Racing - Online Catalog: Electronic Wheel Scales, Gauges, Pyrometers, Chassis Setup and More![/url] How to Choose Your Tire Gauge Things to think about when purchasing a quality tire gauge PSI Range ~ The most important decision is to get a gauge that works within the pressure range of the tires that you will be using the gauge on. For example, if you run 30 psi in your tires then you should get a 60 psi gauge. If you run 15 psi then you should get a 30 psi gauge. All tire gauges work best in the middle of their range. PSI Increments ~ PSI increments are another thing to consider when choosing the correct gauge. The finer the increments, the more accurate reading you will get. Digital ~ Digital gauges are great, however the cheaper the sensor the less accurate the gauge is. With these gauges you get what you pay for. Analog ~ Analog gauges are a great unit of measurement for the money. Normally, the bigger the face size the better the gauge is. Face Size ~ The larger the tire gauge the more accurate it is, in most cases. Hose Length ~ Longacre has 2 different hose lengths available, 14" and 17" for those hard to reach areas. Chucks ~ Longacre has a swivel tire chuck and a standard non-swivel tire chuck. The swivel chuck is a very nice way to go. If the hose gets twisted up you can correct it with a swivel chuck Holds Pressure ~ Do you need a gauge that when you check the pressure you can still read it when you pull it off the tire? Bleeds air ~ All Longacre tire gauges will allow you to bleed off air when checking the tire pressure. Protective Bumper ~ All Longacre tire gauges have a protective bumper. GID Face or Backlight ~ Do you race at night or in a poorly lit pit area? If so maybe you need a GID (glow-in-the-dark) analog gauge or even maybe a backlit digital gauge. Liquid Filled ~ Here is the scoop on liquid filled tire gauges. Liquid is used to soften the blow of air pressure when it enters the gauge. Just think, if you have 30 pounds of pressure then you have 30 pounds of pressure blasting the gears inside the gauge. That abrupt movement inside the gauge is what wears them out. However All Longacre tire gauges have a dampening system built into the gauge head that softens the blow of air pressure, therefore helping to protect the gears. Case Included ~ The most important way to keep your gauge accurate is to keep it in a foam lined case. When your gauge is getting bounced around in your tool box while hauling it to the track or getting dropped, it will lose its accuracy. Keep your gauge in a case at all times when possible. A couple of them on Amazon.com [ATTACH=full]226444[/ATTACH] [ame=http://www.amazon.com/Longacre-50347-Digital-Tire-Gauge/dp/B000VB43L0]Amazon.com: Longacre 50347 Digital Tire Gauge: Automotive[/ame] [ATTACH=full]226445[/ATTACH] [ame=http://www.amazon.com/Longacre-50402-Deluxe-Glow-Gauge/dp/B000F1YW94]Amazon.com: Longacre 50402 Deluxe Glow Tire Gauge: Automotive[/ame] Check out their other products: [url=http://www.longacreracing.com]Longacre Racing: Precision Racing Tools: Electronic Wheel Scales, Gauges, Pyrometers, Chassis Setup and More![/url] [/QUOTE]
Insert quotes…
Verification
Post reply
Staff online
Griffin
Administrator
Members online
j0eycantrell
drew5580
NJ2020
ReddingRaptor
Gumby
mwaite09
Dano182
RaptorFun
nealhoney
Jenner1
Kronos2300
broskibrobro
kirkb
Raptor50
Fasteal
Nv Guy
SonicBlueOval
az_gen3
aostrows
CecilK12
beemerb0y
flyitaway
CleverGirl_
Griffin
Turning Blue
Keith88
zachery55
MurderedOutSVT
MZRaptor72
BoostCreep
SeasickLI
3Dog
ryeabs
BfloRaptor
jdm_sixtwo
HOLLYWOOD 1
Ryan Csaftis
taquitos
mcemd1
Oldfart
Howling_Coytote
njhummer18
GCATX
TD0627
Johnny@Apollo-Optics
The Car Stereo Company
Sand_Limo
fkim119
tonythis
yoopercharged
... and 45 more.
93,408
56,694
forcefed23
Forums
Accept
Learn more…
