Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Exterior Modifications Forum [GEN 1]
Bed rails access/drilling for chase rack
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="JtoU" data-source="post: 1102921" data-attributes="member: 21221"><p>Now since you started this thread, we want to see bed cage build thread. Sooner the better, as you know we're not that patient. </p><p>This would be something i would try out but i don't have any dimensions of the bypass rack nor don't know how much there is room on the side/behind of shocks. I've looked pictures and did some measurements on bed of truck, i used my tire rack drawings too since it has all the same bolt locations. This kind of main hoop should fit there and would be easily tied to rack where it's mounted to bed bolts. All other mounting places are marked. It does stay inside of bed which i think looks better and are easily removed for the winter. It has good clearance to back window too when it's inside of bed, i know now that those beds move a lot. If i would have installed my light rack for last trip it would have dented cab. Those bed marks on side of cab are plenty enough, so keep it farther away from it. Rendering should give you good idea or not <img src="/styles/default/xenforo/smilies/crazy.gif" class="smilie" loading="lazy" alt=":crazy:" title="Crazy :crazy:" data-shortname=":crazy:" /></p></blockquote><p></p>
[QUOTE="JtoU, post: 1102921, member: 21221"] Now since you started this thread, we want to see bed cage build thread. Sooner the better, as you know we're not that patient. This would be something i would try out but i don't have any dimensions of the bypass rack nor don't know how much there is room on the side/behind of shocks. I've looked pictures and did some measurements on bed of truck, i used my tire rack drawings too since it has all the same bolt locations. This kind of main hoop should fit there and would be easily tied to rack where it's mounted to bed bolts. All other mounting places are marked. It does stay inside of bed which i think looks better and are easily removed for the winter. It has good clearance to back window too when it's inside of bed, i know now that those beds move a lot. If i would have installed my light rack for last trip it would have dented cab. Those bed marks on side of cab are plenty enough, so keep it farther away from it. Rendering should give you good idea or not :crazy: [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
STHenry
Wangchung83
Badbrad
Soulforger
Evil Peaches
Tonecapone
P4SHOCAT
labradorguy
CecilK12
ToadSmasher2K1
MidnightSpecial
03Cobraraptor
BoostedToy
jAKe47
rp2024
GordoJay
EagleFive
New recaros
awd5906
Rickmeister
Chewie
SurfRaptor
gunther
ArizonaKevin
SJC8713
BoostCreep
xlover
Russ103
TX RNmedic
Fireman Dave
someday
MeFryRice
MotoDad
Sharpie69
Hard R
TennesseeRaptor
OEMPlus Raptor
Gumby
adventureduty
Al Terp
Frofan
uncboysetsfire
GCATX
TiFJ
Dbone
Goose8651
DougDimmadome
mlax
moto727
... and 51 more.
93,518
56,798
CF1975
Forums
Accept
Learn more…
