- Joined
- Jul 18, 2017
- Posts
- 2,853
- Reaction score
- 1,321
We now have the AlphaRex NOVA Series LED Projector Headlights available in our online store
http://www.4x4truckleds.com/vehicle-specific-ford/2017-2018-f-150-raptor/headlights-fog-lights/
AlphaRex is another option for those looking to upgrade their headlights to something with a lot more light. A sleek design and killer output make this a great option.
DESIGN
We use 5 projectors for these Ford F-150 headlights with the LED bar surrounding the light as a DRL and sequential signal light. The LED bar also provides an activation light feature which is a running light when you unlock your F-150. At the middle is our claw signature amber lens signal light. The top 3 projectors are for low beam, while the bottom 2 projectors are for high beam. The high power LED produces a 6000K light output and an outstanding projection.
PROJECTOR TECHNOLOGY
The NOVA-series full LED headlights are composed of our patented 3D LED projector. We apply the Osram Oslon black flat LED chip for our projector, and the projection cut-off line is perfect for American LHD regulation.
FEATURE
The NOVA-series headlights come with signature activation light feature, which is a sequential light show when you unlock your car. Our headlights also come with sequential signal light that give you an enhanced style when you change lane or make a turn.
HOUSING
The chrome housing gives your truck a stock housing look and match your truck if you have a lot of chrome accessories. On the other hand, the black housing gives your truck a sporty look and easily match with any color truck and front grill. The jet black housing is our special designed housing that has the glossy look mixed with the black paint, and it will give your truck a sporty and luxury look at the same time.
LENS
Our lens made of polycarbonate plastic and is covered with a layer of anti-fog agent, which allows better light output in extreme weather. We also apply another coating to protect against yellowing and oxidation.
SAE/DOT COMPLIANCE
All our headlights are compliant with SAE and DOT FMVSS108 regulations, and all our products are certified to ISO-9000, ISO-9001 and ISO-9002. We inspect every detail of the lights to make sure we are satisfied and so are our customers.
INSTALLATION
Our Nova-series full LED headlights are plug-n-play direct replacement for your truck. Because our headlights have DRL feature, if your truck does not have DRL feature, you will need to apply the DRL module included in the package; if your truck has DRL feature, you do not need to install with the DRL module. No modification is required for installing these headlights; thus, our Nova-series headlights are easily removable when you need to return or sell your truck and it will not void your factory warranty.
CHROME
http://www.4x4truckleds.com/alphare...-nova-series-led-projector-headlights-chrome/
BLACK
http://www.4x4truckleds.com/alphare...r-nova-series-led-projector-headlights-black/
MIDNIGHT BLACK
http://www.4x4truckleds.com/alphare...ies-led-projector-headlights-mid-night-black/
DESIGN
FEATURE
HOUSING
LENS
SAE/DOT COMPLIANCE
INSTALLATION
CHROME
BLACK
MIDNIGHT BLACK
