- Joined
- Jul 18, 2017
- Posts
- 2,853
- Reaction score
- 1,321
If you're tired of your fog light brackets bending due to their design or the inability to easily swap out lenses when you want to. Or maybe you wanted your lights aimed differently... well the SPP Triple Fog Light Kits is the kit for you.
The SPP Triple Fog Light Brackets are made right here in America from Stainless Steel. Designed by a leading Roush/Raptor dealer to fill a need in the market place.
First let's talk about the mounting points. The stainless steel bolts go right through the bracket frame. unlike some other brackets on the market that have mounting tabs on them, these will not bend or flex on you. The lights sit in a channel that lets you slide them left/right/forward/back.Did we mention that once all of your lights are mounted you can also move the entire bracket assembly up and down in your opening? This will ensure all of you folks with OCD get them perfectly centered.
We always have these kits in stock at our NY warehouse and you can pair them with Rigid or Baja Designs lights. When you grab a full fog light kit from us you'll also receive our custom made, all-in-one harness that allows you to connect the 3 pairs of lights up to 3 different upfitters. We have multiple harnesses available, depending on which kit you buy (so we're not going to make you use an adapter to convert a DT connector to a Weatherpack connetor).
Mix/match Baja and Rigid as well, we can custom tailor the harness for you.
2017+ Ford Raptor Triple Fog Light Kit (w/Baja Designs Lights)
http://www.4x4truckleds.com/2017-ford-raptor-triple-fog-light-kit-w-baja-designs-lights/
2017+ Ford Raptor Triple Fog Light Kit (w/Rigid Industries D-Series)
http://www.4x4truckleds.com/2017-ford-raptor-triple-fog-light-kit-w-rigid-industries-d-series/
2017+ Ford Raptor Triple Fog Light Kit (w/Rigid Industries Radiance Pods)
http://www.4x4truckleds.com/2017-ford-raptor-triple-fog-light-kit-w-rigid-industries-radiance-pods/
2017+ Ford Raptor Triple Fog Light Brackets
http://www.4x4truckleds.com/2017-ford-raptor-triple-fog-light-brackets/
Shoot us a message, email ([email protected]) or call us (866-991-4331) and we'll help you design a system for your truck based on your driving style.
