GEN 2 Bed lights
clark98ut
Liberty Hill, TX
What is everyone using for bed lights? My truck didn’t come equipped with the bed light option, and I’d really like to add something since I have a bed cover.
4x4TruckLEDs.com
It's actually not too difficult
Just grab our Bed Lighting System Kit here: http://www.4x4truckleds.com/2015-ford-f-150-bed-lighting-system-w-baja-designs-s1
This kit includes a single rear BuiltRight Industries Bed Rack Panel (shown in the photo where the shovel is). It can be mounted on the either the driver or passenger side. This photo shows an example of a similar setup, only the light is not the Baja Designs S1 and it's using the larger panel instead of the smaller panel.
We decided to go with the smaller panel so that you can throw light into the whole bed. You could certainly go with a larger panel option if you wanted and aim the light back though.
Just shoot me a PM and we can discuss options/etc...
4x4TruckLEDs.com
You could certainly utilize the Baja Designs Dome Lights as well. The dome lights are essentially the same as the rock lights, only they have an ON/OFF button built in. So you'd just apply power constantly to them. They are small and can tuck up under lots of places.
OR you can do the rock lights and wire them up to an upfitter switch
Rock Lights: http://www.4x4truckleds.com/led-auxiliary-lights/baja-designs/rock-lights/
Dome Lights: http://www.4x4truckleds.com/led-auxiliary-lights/baja-designs/dome-lights/
The Dome Lights & Rock Lights put out 208 lumen each
C
clark98ut
Liberty Hill, TX
Do you know who makes that arm & ball mount in the picture above? And would it work with the S1?
Thanks,
Dan
4x4TruckLEDs.com
It's not light specific so it could work with anything. you'd just need to mount the s1/s2 brackets to the ball mount. There are lots of companies that make mounts, your most popular though are the RAM mounts. They have lots of accessories/things you can come up with. We don't sell them as you can find them on amazon and the skys the limit as far as mounting styles go.
Stroked out
Florida
Buy the pigtails and lights and activate lights with forscan. The rear wire harness comes with sockets to plug in the light pigtails.
