Upgrading Sync 3 v2.0 to v2.2
fidds22
Alberta
Hey there. Does anyone know how to upgrade sync 3 v2.0 to v2.2? I have seen/searched online, but they are all usually v1.0 to v2.2, and I'm not sure if it works going from v2.0 to v2.2. I tried some Forscan stuff and it needs v2.2 to work apparently. Thanks
Bullishone
Interesting. Never knew there was a 2.2 upgrade. Can it be done over WiFi?
Sent from my Nexus 6P using Tapatalk
F
fidds22
Alberta
Well there you go. I swear i looked around, and all i could find was sync 3 v1 upgrade to v2.2 . This should work. thanks!!
---------- Post added at 08:24 AM ---------- Previous post was at 08:21 AM ----------
Well that was short lived. That link is no longer valid.
Toadster
Folsom, CA
I may have the file - let me check [emoji106][emoji106]
F
fidds22
Alberta
What exactly are the improvements?
Im not too sure on the improvements, but i wanted to try the blue theme on my sync, and you need v2.2 to get that with FORscan. I tried it with v2.0, and i had no luck. So i will update and try again.
F
fidds22
Alberta
So i tried the update, worked fine. I now have v2.2 and the Blue Ford GT theme. Looks great. v2.0 would not allow the blue theme for some reason.
