Sneak peak of the PSS Reservoir
SDHQ
GILBERT, AZ
The guys at PSS (Power Steering Solutions) have really put together a nice piece for the Raptor.. This is just one part of the package... I'll have better pics and more info tomorrow for you guys...
Hockster
My 45ft Bluewater Party
Winchester, Va
Nice... Hey, are you locating it out from under the hood?? Sure needs it. Also, the stock system looks like it runs the return fluid through the drivers side of the AC condenser, are you removing that from the system also?
SDHQJASON
Gilbert, Arizona
We are very excited about getting this product out to you guys who are looking to upgrade your steering system!
Here are a couple key features of this high end piece.
• Direct bolt in replacement w/ no additional components required (additional fluid supplied)
• CNC machined from 6061 aircraft grade aluminum
• Threaded o-ring cap w/ 12psi pop off valve
• Built in anti-cavitation valve designed to eliminate fluid ariation / foaming
• Increased power steering reservoir fluid volume with increased flow
• High end AN fittings for factory-like seal to OEM power steering lines
• Made in the USA
More info can be found on our website:
Power Steering Solution Ford Raptor Power Steering Reservoir
Members online
93,180
56,460
khunter
