Has anybody tried this before? They said to do this every 10K miles...? I'm at 15K, debating.
Yeah I kind of always thought it was for high milage cars.Why?
There really is no need unless you have carbon on the valves, tops of pistons, etc.
Sea Foam is a great product.
I would consider it in my Raptor for one reason. I run a lot of E85. Every 3000 miles on E85 you are supposed to run a tank of gasoline. I run Chevron gasoline with Techron about twice as often as required and a can of Sea Foam in the tank at 10,000 miles (or even more often) couldn't hurt. SeaFoam is recommended and compatible with E85... (Sea Foam recommends a can in EVERY tank of E85!) I'm not sure I would pour Techron into E85.
I would not perform the Sea Foam "engine clean" where you run on straight Sea Foam, but I think a can in the tank every 10k is not a bad idea.
