New Contest - If you've purchased any of our, Fog, Light Bar, Rear or A-Pillar Kits... Post Pics & Comment on your experience for a drawing...
Specialtyperformanceparts
Gen 3 Raptor Light Kits
If you have purchased one of our SPV Parts kits, Harnesses, or Brackets and love them! We want to know about it!
Please post your photos... and a comment about your experience and what you like about the products.
It really helps others based on YOUR experience. Many of you send us photos and comments via text and email, and we still want those too! However, we want people to hear it from YOU! Not our translation of your experience and likes... but YOU! Often time we see others comment for their customers. That's not the same and who knows if it's even accurate. Coming from you, it's accurate!
So help us out, and we will have a drawing for a $50 gift card after July 1st. (That's 2 weeks)
We just want to hear from you and see pictures of your kits installed!!
If you have multiple kits, post pics of all of them! Lets do this... For those with multiple kits, we can break up entries.. Pics and comments on one kit = one entry. 2 kits = 2 entries. 3 kits = 3 entries and so on. So if you have Fogs and Rear lights, that's 2 entries, and 2 chances. We really want to hear from you on all the kits you ordered!
So to be fair, we will do 2 drawings for $50 gift cards. So potentially, if you did get and post more than one kit, then you could get both. Or, 2 people will each get one. If you just purchased harnesses or brackets, those will count as one as well, but not 2 since they go with a light for a kit of one kind or another. So post there too. We know many of you may have had your old lights you reused.
Now, not that everyone isn't honest on here. I know you all are, but to be fair in case someone pops on and just gets pics from the internet or something and makes up a review. We will reach out to the drawing winners and obviously verify their name and purchase. We need that for sending you the gift card anyway.
Let me know if you have any other questions!
John
john @ spvparts.com
317-93-GO SPV
RotorOver
Greater Atlanta
Adrenlin
NC
2021+ Ford Raptor OEM Fog Light Upgrade Kit with Brackets & Rigid SR-M Direct Replacement Lights
Easy to install, a direct swap and a factory appearance. Just what I was looking for. First purchase I've made from SPV, and I couldn't have been more pleased!
TXRaaptor
@thebeardedbrand
The Woodlands, TX
Love my Rigid Radiance setup. Especially how easy it was to hook-up the amber backlights to the Raptor’s marker light circuit!
Would say the supplied quick connects didn’t hold too well and ended up just connecting directly.
savela
Baja Designs squadrons pro combo, spot racer and S2 pro cornering w/ amber lenses. Installed with the SPV brackets, relocation harness and triple fog harness. I also have backup light setup w/ S2 pros.
The setup is tight in more than one way. SPV managed to make brackets that accommodate this setup, barely. I think the pocket has a bit more of a backwards slope making it more of a challenge. As they promised, no compromise on fit. They're tight but no rubbing and the beam pattern doesn't seem to be greatly affected.
Attached is the light plus bracket setup. Tips: no need to cut the template, simply place the bracket over the sheet and mark your bracket accordingly. Insert the bolt that attaches the light bracket to the SPV bracket before you secure them to the lights - they won't go in otherwise. Notice the orientation of the light bracket (forward sweep).
I did not need to remove my tire to access install location - simply turn your tire to move it out of the way...plenty of room. I hacked away at the back plastic plate - no sweat, I prefer having it in place to hide the connections etc. Harnesses worked flawlessly. Even though I used the relocation harness, I still have my fogs connected to the fog switch - I can change on the future if needed. Combos are on Aux 1 and Spot on Aux 2. Reverse are on Aux 6 with the included SPV harness as well. Tips: For the backup light harness (the long one), use a fiberglass pull rods to run it through the frame (very clean install).
Night pics will be added later. It's a great setup. If you're hesitant to pull the trigger on the Racers, don't. Just the baddest lights I've ever seen. The amber lenses on the S2 PRO are also awesome - crisp yellow light.
WTX
The Permian Basin
No need to be long winded. I bought the Baja Designs squadron pro fog replacements. Drive/combo, wide cornering and wide cornering amber. And the S2 pro’s for the rear. Just added the squadron pro racer spot to the a pillar a bit ago. I didn’t want massive lights in the way. Baja Designs stuff is top notch and John’s harnesses are first class. Great instructions and easy install.
