Lower Control Arms
JustAhRaptor
Louisiana
I have a 2020 raptor with a 4” lift from Fabtech. The truck only has 23k miles on it. And there’s a squeak, sounds like it’s coming from the lower control arms.
I’ve had people look at it around the house, they say it’s my shackles on the back, an actual mechanic says it’s my lower control arms, and some said it was the slip pin.
So I was wondering if anyone else had a similar problem to their truck squeaking while going over light bumps or uneven terrain. Just looking for some insight
Nex
RIP CoronaRaptor
Washington State
You will be vilified for putting a 4in lift on a Raptor … ima guessing
Welcome to FRF. Sorry to hear about owning a nurtured Raptor. I would take a look at the sway bar end links.
FordTechOne
Detroit
Who installed the lift? The lower control arm to shock bolt torque is 406 lb-ft, and it needs to be tightened at ride height. Without a 4 post lift and a torque multiplier, it’s near impossible to properly torque it.
J
JustAhRaptor
Louisiana
Winn Customs done the lift, unfortunately he went back to work in the oil field about a year ago. He told me to take it to a front end shop. I did as he said, and these jokers wanted to spay white lithium on everything but their momma. I’m about to the point to have it hauled somewhere because North Louisiana doesn’t have any reputable Front end shops.
