How many spares do you run?
Fred
Richmond, VA
Two, a power tank and a tire plug kit. Have used both spares, plugged one and borrowed one off the chase trailer before on a run. I have seen guys get flats as soon as we hit the trail head. So two are needed if you want to venture very far into the desert.
I also read on here before, just carry one and borrow a buddies tire if needed. That's all well and good till someone ruins your $450 borrowed tire. Best bet is always be as prepared as you can be to fix your own truck.
x2...
MajorAR
Kansas
I normally only carry one spare. Desert trips....throw another in. And then I always have a tire plug kit in the truck. Cheap insurance.
Yukon Joe
Russellville, AR
after 3 TRR's I now also carry:
brake caliper bolts - 4
lower A-arm pins - 2
bolts to act as stand in event of a arm break - 2
:Wedgie:
Peter - do you have the post numbers handy? If not don't worry about it. I'm capable of looking them up.
For you guys running two spares in the bed on a rack similar to Outlaws/Saints, how much is the view obstructed through the rearview mirror by the tires?
IMO - It's quite a bit. But the stock head rests also obstruct my view. Makes it hard to back the truck up when you have to turn around / back out of a narrow trail.
Yukon Joe
www.RUNRAPTORRUN.com
Mjolnir
Colleyville, Texas
For the caliper bolts they are W714743-S439
It's a package of four. For the a-arm pins I use rpg's setup so I got them from Corey
treypal
Lord of the Raptors
Riviera TX
Used to carry 2 spares and a plug kit.
Still carry. Iwe. Lca bolts. Ps pump. Tie rod. Caliper bolts. Uca pins. Tie rod pins. U joints. Fluids. Lower shock bolt. Etx.
And I don't even have a raptor.
hungerforraptor
Hartford, CT
2 spares myself (one under too) and a powertank tire kit.
Where did you get this bed rack? This is exactly like what I've been looking for.
