Geiser Spring Install at home
Jhollowell
Everett, wa
So i was able to remove and install Geiser springs on mid perch in my garage. I used a HF 20 ton press and a few custom tools and it worked surprisingly well and went way more smooth than i was expecting. I did hide behind a thick welding blanket on the first one but you can see in the videos it was pretty anti climactic. FYI make sure to double check the orientation of the hats before you put the spring on, especially if you have schrader valves. It only took me 3 tries to get it lined up right on the first one. I got the second one on the first try.
Removal
Install
