forscan \ Glarefree headlight question
offcamber
DFW Texas
I decided to try to enable the glarefree headlights on my 2022 Raptor. Using the below settings which I believe I found on this forum, I first backed up each module and made the changes going down the list until I got to HCM 734-01-04 and the D1 setting through me since it was only the 2 digits and it did not have xx's around it, so I decided, better safe than sorry. I went back and then loaded my backup of each module, then wrote all to restore it to the original config, being sure to turn the truck off and open and close the door between each section. As far as I can tell all settings that I changed are back to how they were in forscan before I changed anything...However, when I look at Lighting in vehicle settings. The Glare free toggle is there instead of adaptive headlights. Can someone explain what could be going on. Aside from Bambi mode a couple of weeks ago those are the only settings I've changed. Thanks in advance!
Below are my settings:
flockofraptors
NJ
Is your question that you're trying to revert to stock, i.e., adaptive in settings, but 'glare free' still shows in settings even after reverting all changes?
Not sure why that's happening.
If you want to move forward with glare free, the correct entries are below especially the 'D1' line:
APIM 7D0-09-01 x1xx xxxx xx--
APIM 7D0-09-03 xxCx xxxx xx—
Reset APIM after these two changes before making remaining changes
IPMA 706-01-01 xxxx xxx9 xx--
SCCM 724-04-01 xxx4 xxxx xx--
IPC 720-01-01 xx8x xxxx xx--
IPC 720-10-01 xxxx xxx3 xx--
HCM 734-01-01 xxxx xx01 xx--
HCM 734-01-02 x3xx xxxx xx--
HCM 734-01-04 xx56 D1--
O
offcamber
DFW Texas
I guess it just needed time. When I started the truck up a bit ago, it had reverted back to Auto High Beams
O
offcamber
DFW Texas
Thanks for that. I got it working tonight. Definitely an amazing upgrade.
taquitos
Seattle
Out of curiosity, what happens if you do the APIM stuff second? I went through in order then realized I made a typo on one of the APIM codes. Changed it without reverting back, so essentially out of order, and all seems well.
flockofraptors
NJ
If you're getting the "green A" icon and if it seems to be working (test it at night on an isolated road), then maybe it's all good.
taquitos
Seattle
Menu item is there as it should be, green A is there, appears to be working as it should on a dark road, and no error messages. I take it there isn’t some little issue if it’s not done right it just straight up wouldn’t be working?
Also does anyone know if it’s possible to decrease the speed threshold for the brights to come on? I’ve looked a little and can’t find anything. Sure would be nice though.
brysgarage
MA
In Forscan when you use the SCCM configurator to enable glare free (instead of AS BUILT, all other modules programmed using AS BUILT), it places a “3” instead of a “4” in the 724-04-01 line. When using a “3” I noticed I now get the blue highbeam symbol when the high beams are active which was not present when using the “4”. Additionally when using the “4” I would get DTC’s in the IPM modules. Those are gone now with the “3”. Does anybody have any idea what the difference between the 3 and 4 is?
Thanks!
Littlefx4
Thanks!
Sounds like you answered your own question…3 gives you the “blue high beam” symbol (regular auto high beams) whereas 4 give you the “green high beam” symbol (glare free).
Just ensure you have a 4 in the correct spot as outlined in post #1 and you’ll be fine. Erase the DTCs & cycle the engine. Did you remember to reset the APIM?
