So I suppose the next question is... Is there a such thing as an electronically locking Torsen differential?
ehhhh. So much misinformation in this thread. At least you are trying to learn so I will be constructive.
TorSen (short for Torque Sensing) is an LSD. It will allow one wheel to spin UP TO a certain amount more than the other wheel before it locks them both. The threshold is called a TBR or Torque Bias Ratio. In the Gen 2 Raptor, TBR is 3. So, the torsen is an open diff till one wheel spins 3 times as much as the other, then it locks and they both spin at the same rate.
Anytime you lock a diff either electronically or using air compressors (ARB), you have what's called a selectable locker. When you select the lock, you take away any torque bias between the two wheels and both wheels spin at the same rate. You lose the advantages of letting one wheel spin slightly faster than the other and in return, you gain a true 50-50 split in power, on command.
LSDs are good for performance cars and higher speed driving in general because you want a bit of slip and not be fully locked all the time, however you dont want a complete open diff either.
Locked diffs are generally good for slow speed crawling. And deep snow.
There is no such thing as "electronically locking Torsen"
