diff service
does anybody know if there are lube locker or similar style gaskets available for the front and rear diff covers? going to be changing my fluid soon and can't for the life of me figure out what type of front diff this thing has
CarmanKyle
Pasco, WA
Front diff is a Ford 8.8 reverse rotation.
Black RTV for the 'gaskets'
R
that makes life easy. I absolutely hate using rtv for the gaskets. lube lockers are re useable and you don't have to wait for the rtv to dry to fill the thing.
Chris@FreedomMotorsports
FRF Gofur
Woodlawn, Virginia
The RTV below is what I use now. I use to use black RTV, but this stuff is specifically designs to be used on differentials.
https://www.amazon.com/dp/B0023GM2KK/?tag=fordraptorforum-20
The differential gear lubes I use and highly recommend are linked below
Front diff (need 2 quarts)
AMSOIL Severe Gear® 75W-90
Rear Diff (need 3 quarts with stock cover and 5 quarts with aftermarket cover)
AMSOIL Severe Gear® 75W-140
If you aren't already, you can join the Amsoil preferred customer membership to save up to 25% off the retail pricing at the link below. It is well worth it and saves a bundle if you plan to properly maintain all your vehicles and toys. Let me know if you have any questions.
Become an AMSOIL Preferred Customer and Save
engine45
South Florida
Hey Chris are you guys putting in the friction modifer in the rear diffs when changing the fluid? the lil 4oz squeeze tube stuff ive seen in the youtube vids. or is the amsoil alone enough?
EricM
OHIO
No RTV is better than "The Right Stuff".
Does the front diff not have a drain plug anymore? My old F150 with the 8.8 IFS had plugs for fill and drain. You can add a drain plug to the rear cover if you want to change it often.
Ruger
Northern Nevada
Be advised that Ford glues the differential covers on as if they never intend you to service them. That's not so hard on the rear because you can remove the spare tire and gain complete access to the whole circumference of the differential cover. Not so the front. It's shoehorned in there real tight, and I didn't even try to remove the cover. I just pulled the fill plug and pumped out as much lube as I could. I got about 3/4 of it out, which isn't too bad if you service it regularly. No drain plug on the factory front differential.
