Finished Deaver springs install
st33zygill
Los Angeles, CA
Hello, I just had geisers 2.5 springs installed up front along with deavers +3HD in the rears.
My question for those running 37s and deavers in the rear, did you add any additional rear diff fluid?
4C4FA3A6-4AB1-45E6-BC05-ACA0DC5A7CB8.jpegI have the ford performance rear diff cover currently filled up to the lower fill port.
Sig Fanboy
WV
I’m confused on what the springs have to do with the oil level… but here goes.
I filled mine until oil came out the upper fill port as it was running out the lower port after only 2 quarts. The ole interweb said the proper amount of oil was 2.75 quarts.
nikhsub1
Los Angeles
You are over filled... seems crazy but it will sap some horse powahs.
thatJeepguy
GA
When you lift the suspension , pinion angle pivots and the pumpkin tilts, requiring a bit more in theory. The oblique shape of the diff housing causes the oil to settle more towards the sump . The spicer diff cover has provisions for that.
Sig Fanboy
WV
I suppose I knew that. But traditionally I’d be thinking about installing a 3-4 in lift kit on a non Raptor platform. Deaver +3 is basically 1in of lift from stock. Seems there would be a pretty minimal change in oil level.
I see you are the Jeep guy.
I’m sorta looking for a TJ Rubicon, preferably an LJ. I naively thought a few months ago picking up an older Rubicon would be cheap and easy, I know very little about jeeps. Little did I know everyone is looking for a TJ Rubicon LJ. A buddy scored a nice one with lots of nice upgrades and almost no rust.
I’m not spending enough money on 2 Raptors, why not get another money pit!
thatJeepguy
GA
Yea i agree with you both i don't see the need to run extra oil in the pumpkin either with that deaver +3.
Nice dude do it! Everyone wants an LJ because it was the unicorn with long wheel base, 2 door and the 2006 version of the 4.0 which will literally run forever if you change the oil with walmart **** every 3-5k. Lockers fore and aft as well. They are somewhat rare… However require a lot of lift to fit even 35’s. The simplicity of sold front axle is refreshing and superior to Ifs for
Slow and tight trails
As well as super easy to work on yourself. Best to get a big ol fat warn 10k winch and bumper, go till’ you get stuck and winch out. They can be a blast and very handy.
Sig Fanboy
WV
As soon as I get hydralic bumps on my Gen 2, I’ll be at the end of my vision for my Raptor. Or at least phase 1. Phase 2( bypass rack, mid travel, glass) is gonna take some time. A TJ will satisfy my modding desire and is less than a modded SXS. I doubt I end up with an LJ but pretty sure I’ll end up with a Rubicon TJ eventually.
Old-Raptor-guy
USA
I know guys with more $$$ in their SxS than most Raptors.
