Can we talk rim rub?
Guy
I’m thinking of going with 18x9.5 +6 offset wheels with 305/60/18 true 35 inch cooper st Maxx tires.
Is anyone running something similar?
I’m going to go with 2 inch collars up front and stock height +2 deavers.
I don’t want to get into a running mess. I could also go 295 which is 34.3.
Thoughts welcome
But ... what if things are just to tight for @Guy?
G
Guy
You guys aren’t right.
In retrospect I can see I should have said TIRE RUB. Anyway.... someone just answer my question. :)
ICLOSEM
Title does read completely different. I wasnt sure if I should click on it or not. Then I just said F it and went for it!!.
whan
Chad
Talk to me man.
Define.... ill be fine.
With the collars? Turning at full lock? Details man
Can't say I know for sure but think it'll be close but may be fine
Normally on standard 17x8.5 a +6 offset with no lift is close, but likely doesn't rub in any turning scenario on level ground (some people have reported a 0 offset does slightly)
Wider wheels push the outer edge of wheel out, but tire usually bulges out further than wheel, so it won't be 1:1 with how much further the edge of tire sticks out.
I think ChevyChad thinks it's not much, if any at all - I would think it may be pushed out slightly at the widest point, I'm not sure though... depends on tire deformation
Also depends on tire profile - yours is a true 35 so perhaps that may hurt as well / depends on sidewall lugs.
All this to say I think it'll be close - don't think it'll be too bad if it does rub, and likely only at full lock
I apologize @Guy, but I just can’t take this thread seriously anymore.
This talk of collars and you’ll be fine but if it does rub it would only be at full lock...
:biggrin::biggrin::biggrin:
Yer killin’ me here Guy...
