Best way to have a bed cover and occasionally transport a kayak?
970rap
CO
I go on family camping trips periodically, which normally fills most/all of the bed up to my Lomax bed cover. I'm now the owner of a kayak, which my family would like to bring on some of these trips. Using space in the bed isn't a reliable option for these trips.
What options do I have for retaining some sort of bed cover but also adding the ability to attach a kayak, presumably through some sort of raised rail system? Further, the raised rails, ideally, should be removable. Bonus points if it's semi-easy to do. I'll only need to use this a few times per year and I don't want to be driving around with them on all the time. And I'd need to be able to open the bed cover while the rail system is on.
I see so many options and products out there but I'm not sure what works with what. I assume nothing will work with my existing Lomax cover, which is ok. Any ideas? Is this even possible? Thanks!
HighwaySentinel
︻デ┳═ー - - - - - - -
California
I'd hit up the Realtruck folks on here for your specific application. They are very knowledgeable when it comes to covers.
MDJAK
NY
I asked the same thing a while back. Unfortunately, there's no easy answer, short of as you say raised rails or a rooftop carrier which ain't cheap once you buy the necessary extras for the cross bars. I have 2 12' kayaks and use my enclosed trailer which is definitely overkill, but I only transport them maybe 20 miles each way.
John M BUNMAN
BUNMAN-Adventures, Rescue & Recovery
Las Vegas NV
Nick@Apollo-Optics
I have a solution that would work nicely for you. It's a little pricey, but there is a $300 mail-in rebate going on right now.
Truxedo makes their TS Bed Rails and Elevate Rack. The TS Bed Rails give you the ability to have T-slotted rails with virtually any existing bed cover. Then they make the modular height Elevate rack that are adjustable. They can be set low for a overland tent or max height for paddle boards and kayaks.
Here's some pictures for you.
The first pic is the TS rails and how they install.
And then here's a picture of the rack installed with a bed cover so you can see how it works.
At this time, I have both the rails and the racks in stock. Retail for the two pieces is $819 and $216, respectively. But I'm happy to put a package together for you with discounted pricing and free shipping. And you're able to collect the additional $300 mail-in rebate from Truxedo after the sale.
Feel free to reach out if you'd like any more information.
-Nick
970rap
970rap
CO
Thanks for all of the responses and Nick's suggestion looks like a good one.
Related question - If I were to attach a kayak rack to these crossbeams, which has its own straps and locking system, do I also need to use bow and stern lines? If so, where would they attach on a setup like this (it's not going to hang over the hood)? Everything I've read says they are just a backup safety precaution but are essentially required.
Nick@Apollo-Optics
Trailer hitch for the rear is the usual spot. Or just grab one of the rear tow hooks. For the front, I'd rig a line back to the rack if you won't be able to make it to the hood.
