2017 Raptor Noise at higher speeds & when towing
atsi
Arizona
I have a 2017 Raptor with about 43K miles. I have been getting a noise at higher speeds & also happens more when towing. I took it into the dealer and they had it for 3 days and could not replicate the noise. if you listen to the attached video, the noise is from 14 seconds to 21 seconds, 28-31, 37-39.
Mostly happens around 70-80MPH, but has also happened around 43-48MPH. Normally lasts around 6-15 seconds. If I take a 15 minute drive, it probably happens 5-6 times. Almost sounds like ball bearings going bad, wind noise, or a shuffling of plastic bags. Sometimes there is a slight catching of a gear at the end and with a small thud that I can hear & feel and the issue resolves for a minute or two. This thud does not always happen.
When I towed my boat once with this, it happened constantly.
thx.
Jeff
FordTechOne
Detroit
Sounds like the Integrated Wheel End (IWE) system is partially engaging under load. The IWEs are hub disconnects; when the truck is in 2WD, the engagement collar is drawn off of the wheel hub by vacuum. When 4WD is engaged, the vacuum is removed and a return spring slides the collar on to the wheel hub splines.
Try putting the truck in 4A and see if the noise goes away. If so, you may have a faulty vacuum check valve or a vacuum leak in the system.
A
atsi
Arizona
@FordTechOne , Thanks for the info. As soon as the sound happened again I turned it into 4A and the sound went away, also when kept in 4A, the sound never came on again until i put it back into 2WD. Looks like you solved the mystery. Thx!
Jeff
