13 MyFord Touch Screen off?
The Macf
Vegas
Anyone figured out how to turn the screen completely off in the 13's yet? I can't find anything in any of the supplements.
Thanks,
Chris
mwright4679
Syracuse NY area
I did a post about this shortly after i got the truck.... there is no known way to turn the screen off. Best bet is to dim it as much as possible if it is to bright
Raptor911
Ashburn, VA
You can turn it off:
Click on this:
You will come to this screen:
You want to be on the "Display" Tab (2nd tab down from the left, under "Clock"). Then to the right of "Mode", click on "Off". Your screen will completely turn off. This does not shut down your NAV system. It will just turn your screen off. If you happen to be playing a CD. You can still turn up/down the volumn via the manual dial. To turn on the NAV screen, just touch the screen.
Also to dim your screen just use the light dimmer rocker switch to the left of the steering wheel.
I hope the above makes sense.
swoop1156
USA
I have always wondered this and just figured it out this morning and came here to save the day!!!...then I see that it was already answered. Good going, ruining my surprise! :D
